Please explain to me how this can happen. I had a leaking fork seal on my MNS, figured the air was gone too. When i took the plug out, the fluid shot out about 8 feet. Don't quite understand how it can be.
Forks hold air, but not fluid
1980 XS1100LG Midnight
1991 Honda CBR1000F Hurricane
A cold beer and another one!Tags: None -
Fluid Leak
Hindsight is 20/20. So make sure to relieve air pressure prior to disassembly/ plug removal next time.
When you put air pressure to the fork, the pressure is on the top (rod) side of the piston in the fork. Oil is on the opposite (bottom) side of the piston. If you remove the drain plug with air pressure in the fork - WOOPS! Here comes the oil. It physically has no choice to go anywhere but the least path of resistance (i.e. drain hole).
MP1981 XS1100H Venturer
K&N Air Filter
ACCT
Custom Paint by Deitz
Geezer Rectifier/Regulator
Stebel Nautilus Horn
EBC Front Rotors
Limie Accent Moves On In 2015
Mike -
Yeah, I have been sprayed and that oil fork oil stinks!Hindsight is 20/20. So make sure to relieve air pressure prior to disassembly/ plug removal next time.
MPSkids (Sid Hansen)
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Sentece in signature kinda ironic in this case..........now that's funny, don't care who U are. (sorry, misposted there Skids)81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
I figured it was something like that, but it was funny just the same.1980 XS1100LG Midnight
A cold beer and another one!Comment
