Turn signal troubles. Need help
  • DCracer25
    • Jul 2011
    • 179
    • harpursville NY
    I have a 81 xs1100 venturer, The problem is the signals will light up but will not blink. I have changed the flasher and still the same problem and the 4ways do work. so any help would be appreciated as I would like to finish this bike and put it on the road.
    2 questions;
    1) did you replace the flasher with a stock self cancelling one or an aftermarket?
    2) What type bulbs are you using? (conventional or LED)
    • DCracer25
      • Jul 2011
      • 179
      • harpursville NY
      flasher
      1st? stock flasher. 2nd? no leds at all.
      • mikubuilder
        • Jul 2011
        • 548
        • Westland, Mich.
        if you have a fairing, make sure that's plugged in, and that you have a good ground...
        Nick
        1982 Virago 750 (it's alive!)
          Try a 2 prong automotive flasher. You lose the self canceler but at least it'll flash.
          When you turn on the TS try tapping on the stock flasher and see if it'll start working. They tend to stick after they've sat for a while.
          Sometimes you can get them working again just by MAKING them go and using them a while.
          • DCracer25
            • Jul 2011
            • 179
            • harpursville NY
            flasher
            I have the fairing and have made sure it is grounded good, Ok it has 3 wire plugin which wires do I use? For the 2 wire flasher.
              Yellow w/green stripe & brown w/black stripe
              • DCracer25
                • Jul 2011
                • 179
                • harpursville NY
                flasher
                ok thanks will try that tomorrow and see if it works.
                  Tan and tan/wht. Grn/yel is for the self canceller, leave that slot empty. You can test this with your 2 prong hazard flasher if you wish.
                    Phil is right. I went out and actually LOOKED at it last night and I thought it was as I said. Looked again this morning and it's as Phil says.
                    I guess I need glasses.
                    Thanks Phil.
                      Try unplugging the turn canceller first. If you have loose/dirty connections in it's plug, the turns will light but not flash. The turns will work, just not cancel, with it unplugged.
                      • GLoweVA
                        • Jun 2011
                        • 1957
                        • Virginia Beach, VA.
                        If your voltage is too low they won't blink, try it with the bike running at about 2k rpm.
                        80G (Green paint(PO idea))
                        The Green Monster
                        Got him in '04.
                        bald tire & borrowing parts
                        Scarlet
                        Got her in '11
                        Ready for the twisties!
                        81H (previously CPMaynard's)
                        Hugo
                        Cold weather ride
                        • DCracer25
                          • Jul 2011
                          • 179
                          • harpursville NY
                          flasher
                          brand new battery fully charged. tried 2 pron flasher and it worked.
