Installing Honda gl1100 handlebar! ( need extended lines)
  • sparkfly88
    • Mar 2013
    • 585
    • CedarKey FL
    Well, after plenty of fighting, it runs right!
    Some silly person installed some kinda drag bar on it and I hate it.
    Not knowing the size of the OE handle, and by others recommendations I am in the process of installing the gl1100 bar.
    My problem now is that the brake line doesn't reach....
    I noticed that my brake lines are ancient and needed replacing anyway... So, on ebay I found this,
    I just noticed I also need a new clutch cable.
    The throttle cable looks like it'll work... I think...
    This should cover me I think... Yes?
    Anyone else who installed the handlebar please chime in and lemme know what I'm up against.
    79F
    "Excelsior"
    Vetter IV fairing with speaker system
    OE headers,Jardine slipons
    Hid headlight 6000k
    Stock jets
    Shinko 712 F & R
    Oe hardbags and luggage rack
    TC fuse block
    K&n filter with oe airbox
    Raptor 660 Acct
  • petejw
    • 2269
    • sydney australia
    the other thing I can think of
    is the length of the wires coming from
    the switch blocks.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • sparkfly88
      • Mar 2013
      • 585
      • CedarKey FL
      I'm not too worried about the wires I can splice them myself as ugly it will be, it'll at least work
      79F
      "Excelsior"
      Hid headlight 6000k
      Stock jets
      Shinko 712 F & R
      TC fuse block
      Raptor 660 Acct
      • sparkfly88
        • Mar 2013
        • 585
        • CedarKey FL
        Maybe if I bought the cables meant for the special with the wrist breaker bar....length might be similar
        79F
        "Excelsior"
        Hid headlight 6000k
        Stock jets
        Shinko 712 F & R
        TC fuse block
        Raptor 660 Acct
          I know for certain that I have put bars on that measured very close to the GL1000 bar dimensions with no problems with wire, cable, or brake hose length. But then I have only owned Special models, so I am sure that would help you out.
          • sparkfly88
            • Mar 2013
            • 585
            • CedarKey FL
            Awesome!
            When I get home I'll measure the cables I have and brake line, maybe they aren't even oe...Lol
            If you wouldn't mind measuring the special cables n such that would be a great help!
            79F
            "Excelsior"
            Hid headlight 6000k
            Stock jets
            Shinko 712 F & R
            TC fuse block
            Raptor 660 Acct
            • sparkfly88
              • Mar 2013
              • 585
              • CedarKey FL
              The motion pro part number is the same for the special and the standard...
              Maybe I don't have the oe clutch cable at all....
              79F
              "Excelsior"
              Hid headlight 6000k
              Stock jets
              Shinko 712 F & R
              TC fuse block
              Raptor 660 Acct
                • 8919
                The aftermarket cables are a bit on the long side so they will fit the Special and the Standard, that is the reason for the same P/N. I have taller bars than the GL ones on my bike and the only thing needed to be changed is the brake hose, the clutch cable can be routed differently on the outside of the fork ears to give extra length.
                • sparkfly88
                  • Mar 2013
                  • 585
                  • CedarKey FL
                  SAWEET!
                  So where'd you get your brake hose from?
                  79F
                  "Excelsior"
                  Hid headlight 6000k
                  Stock jets
                  Shinko 712 F & R
                  TC fuse block
                  Raptor 660 Acct
                  • DeanR
                    • Jan 2005
                    • 1499
                    • Finger Lakes NY
                    No help for you, sorry, but Goldwing bars went on my Special with no alterations.
                    80 SG
                    81 SH in parts
                    99 ST1100
                    91 ST1100
                    • sparkfly88
                      • Mar 2013
                      • 585
                      • CedarKey FL
                      WHAT??
                      SO OE lines and brake line doesnt need any alteration??
                      How much did they change out on mine....
                      79F
                      "Excelsior"
                      Hid headlight 6000k
                      Stock jets
                      Shinko 712 F & R
                      TC fuse block
                      Raptor 660 Acct
                      • GLoweVA
                        • Jun 2011
                        • 1957
                        • Virginia Beach, VA.
                        Originally posted by sparkfly88
                        WHAT??
                        SPECIAL different than standard. according to your signature you have an F (ie.standard), Dean has a special.
                        80G (Green paint(PO idea))
                        The Green Monster
                        Got him in '04.
                        bald tire & borrowing parts
                        Scarlet
                        Got her in '11
                        Ready for the twisties!
                        81H (previously CPMaynard's)
                        Hugo
                        Cold weather ride
                          • 8919
                          SAWEET!
                          I used a 22" caliper line I had laying around. Whoever put the low bars on your bike may have put a shorter hose on there. Just measure how long you need and there are many suppliers that can make you a custom hose with fittings. MikesXS sells a few different lengths that may be close to what you need.
                          • sparkfly88
                            • Mar 2013
                            • 585
                            • CedarKey FL
                            So, stock cables are larger on the special, but the aftermarket is longer to fit both......
                            I havent checked the cross referencing on the brake line yet.
                            79F
                            "Excelsior"
                            Hid headlight 6000k
                            Stock jets
                            Shinko 712 F & R
                            TC fuse block
                            Raptor 660 Acct
                            • sparkfly88
                              • Mar 2013
                              • 585
                              • CedarKey FL
                              http://www.mikesxs.net/product/29-6520.html
                              "Fits non-stock high bars"
                              No measurement though
                              79F
                              "Excelsior"
                              Hid headlight 6000k
                              Stock jets
                              Shinko 712 F & R
                              TC fuse block
                              Raptor 660 Acct
