well i finally finished my billet trees 6061 T6 aluminum. used the original neck shaft just cut the weld out of the old bottom and made an interference fit into the new bottom and plugged the bottom to make it solid. 1.5 inches thick and polished to death. built the warning lights into the top tripple, moved the ignition to the frame and fitted nice carlini chubby drag bars and harley hand controls. to top it off, a headwinds knock off headlight and mirrors with led signals to clean up the front. new clutch and throttle cables specially made to fit and some wiring changes to make it all work. who says you can't customize. have autocad and mastercam renderings for these tripples if anyone wants them but you have to find your own CNC machine or machinist.
