billet tripple trees
  • crawlspace2112
    • Jan 2004
    • 25
    • regina, Sask, canada
    well i finally finished my billet trees 6061 T6 aluminum. used the original neck shaft just cut the weld out of the old bottom and made an interference fit into the new bottom and plugged the bottom to make it solid. 1.5 inches thick and polished to death. built the warning lights into the top tripple, moved the ignition to the frame and fitted nice carlini chubby drag bars and harley hand controls. to top it off, a headwinds knock off headlight and mirrors with led signals to clean up the front. new clutch and throttle cables specially made to fit and some wiring changes to make it all work. who says you can't customize. have autocad and mastercam renderings for these tripples if anyone wants them but you have to find your own CNC machine or machinist.
  • xssiveone
    • 766
    • Windsor,Ontario,Canada
    Sounds like a nice custom. but where's the PICTURES??!!
    Brian
    remembering the same thing!
    • buffalo
      • Aug 2002
      • 141
      • Carson City, NV.
      I gotta see this! Please post pics!!!
      buffalo
      80 XS1100SG
      • Targetman
        • Feb 2003
        • 130
        • Oshawa Ontario Canada
        Yeah, Baby.... I like short bars too.
        Lets see these pictures....
        1979 xs1100sf
        1972 cb500 four
        • dntemp_ca
          • 167
          • Kenora, Ontario
          Yummy! Please post pics. Are you machining forward controls next?!
          Dennis
          • crawlspace2112
            • Jan 2004
            • 25
            i just finished fitting everything, took measurements for master brake hose. i'm using the russel preformed hoses and fittings to do this. slid all the wires through the bars, forgot the wires for the turn signals on the mirrors so i'll have to start over again (dang). new neck bearings, adjust the fork stops. i'm doing a complete motor job. standard pistons were good but new rings and hone plus the second gear fix is done, needed new hy vo chain. did a multi angle valve job so i'll have to adjust valve lash. painted my frame tonight so i'll have to wait a couple of days before i can make it a roller again. forward controls are in the works but won't be ready this season. next year all new tank and fenders, cut the back of the frame off, lower the seat rails and make my own fender struts. new 11 inch rear shocks with way more rake on them. my plan was to do it all this year thats why i stripped the frame but time and money cut my plans short this year, everybody is riding already and i'm still building .pics... i don't have a digital camera but you bet there will be pics, lots of them. hang on i'll get them
            • Bill__Woods
              • 281
              • Circleville, Ohio
              Hi crawlspace,
              I would love to have the autocad and mastercam renderings. i have a few friends that are machinists & they have a CNC machine. If you can email the renderings to bill_woods@earthlink.net
              I can't wait to see the pictures of you handiwork.
              Ride it Safe.
              Bill Woods
              1981 Yamaha XS1100SH (Eleven Special)
              1985 Kawasuki GS425 Mojave ATV
              2006 Yamaha Wolverine 450 4x4 ATV
