Carb butterfly seals
  • spivey
    • 18
    • Tulsa,OK
    I'm in the process of doing a complete rebuild on the carbs for my 78 e model. Before I install the butterfly shaft seals should I soak them in silicone first to be proactive to fight drying out or just install them as is? The seals that are coming out are the originals and are hard and starting to leak. Any opinions?
    Considering those are most likely the original seals, they had no coating, and lasted about 30 years, chances are you replacements will be fine for longer than you will own the bike.
      Hi DGXSER,
      OTOH, the replacement seals may be made from an inferior compound and the stuff they sell as gas these days eats elastomers.
      Lube 'em up, I'd say.
      • WMarshy
        • Apr 2009
        • 2402
        • Mexico NY
        I second that. I dont own any currently but would probably go buy some o-ring lube.
        '79 XS11 F
        Stock except K&N
        '79 XS11 SF
        Stock, no title.
        '84 Chevy K-10 "Big Blue"
        • petejw
          • 2269
          • sydney australia
          any seal that u fit should have a small smear of rubber grease on the seal
          and shaft, also check that they are the correct size
          apparently they come in 2 sizes, the last time I bought
          some they were slightly smaller on the outside diameter
          by around half a mm from memory.
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          1981 xs1100 RH (aus) (5N5)
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
