Well put gas in the tank, plumbing all was great, ran down into the bowls and No. 1 carb just PISSED it out, but not out the throat, out the bowl gasket!!! ^&%$%^#!!!!! gotta pull the carbs off now and see what the heck that is all about. The others all behaved fine. Very weird, that gasket went on just like the rest. Hmmmm, time for some aviation gasket #2 as a backup maybe??? It's supposed to be fuel resistant.
..the carb bowl. Not sure how new to you the bike is. I have a set of carbs did the same thing to me, turned out the PO of the carbs had a later style bowl on the earlier body. Due to the very slight diff in alignment of the enrichment jet, the bowl did not seat 100% and leaked. Swapped bowls out and fixed the slightly deformed tube, works great now.
