vacuum plug size
    • 2074
    vacuum plug size
    Does anyone seem to know off hand the vacuum plug size?I need to replace mine-they are cracked.
    • 8061
    I recommend you go to the dealer and buy them. They are cheap enough and can take the heat better than what you're going to find at the local auto parts store. I have attached the part number.
    16G-13569-00-00 PLUG,BLIND
    • TADracer
      • 1417
      • Kenner, Louisiana USA
      And to further what Marty has said, if you cannot get the OEM caps that last a bit longer, go for the auto parts store caps and change them once a year as routine maintenance.
      Mike Giroir
      79 XS-1100 Special
        • 2074
        For now i will go to auto parts store and change them until i can get some dealer ones.
          • 8891
          I just take some 1/8" ID vac hose, cut off a piece about 1" long, shove a BB in one end, put some dielectric grease on the other end and slip them on. Old Yamaha vac hose that hasn't cracked in 30+ years works perfect, new cheap vacuum hose will crack just like those caps, BTDT. Either way, 1/8" ID will fit.
            • 2074
            Phil-why the grease? Just curious.I got a piece of the OEM vacuum hose so i will try this!
            • GLoweVA
              • Jun 2011
              • 1957
              • Virginia Beach, VA.
              The grease is probably to prevent the hose from baking/sticking onto the carb nipple and thus never being able to pull it off for a carb sync.
              80G (Green paint(PO idea))
              The Green Monster
              Got him in '04.
              bald tire & borrowing parts
              Scarlet
              Got her in '11
              Ready for the twisties!
              81H (previously CPMaynard's)
              Hugo
              Cold weather ride
                • 8891
                Yep, they come off every time no problem, it sucks when they get baked on and stuck, especially the inboard ones.
                • CaptonZap
                  • Jun 2010
                  • 1748
                  • Denver
                  Yep, I knew there was a reason to keep the vacuum fuel valves. They connect to the center two carb tubes.
