Rear Brake Lever Travel?
  • MPittma100
    • Aug 2011
    • 2359
    My 1981H Venturer has a bit of an issue when I apply the rear brake. It travels too far. I really have to pivot my foot a lot to get it to apply the brake well enough. It would skid the tire if you pushed it hard enough. So it is working.
    The bike has 26K miles. Pads have plenty of lining on them and I suspect they are OEM - do not know for sure. It had even more travel when I first acquired it. At that time I checked the free travel adjustment (which was in spec.) and bled the brake. The fluid was very discolored. This did help some, but it has considerable more travel than my 79SF. The pedal will not build if you pump it.
    The SF has EBC pads, but I do not know if that applies. I realize that the Venturer is heavier, but the travel is too much and causes me to really "put my foot down". Almost makes you want to use your heel? I have tried adjusting the lever at the master cylinder and that does bring the pedal up, but there is no more free travel.
    Any suggestions are welcomed.
    MP
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
    • 8766
    You could move the pedal one spline so it is further up and readjust the plunger bolt to where it feels comfortable. There should be a witness mark on the pedal and the splined shaft for the proper position.
    • MPittma100
      • Aug 2011
      • 2359
      Pedal Height
      Would there be any difference if I adjusted the plunger bolt without reclocking the pedal? Clocking is correct now with witness mark. I am wondering about the necessity of keeping the .050" free travel.
      MP
      K&N Air Filter
      ACCT
      EBC Front Rotors
      Mike
        • 7861
        Did you do anything that could have introduced air into the system?
          Hey Pitt,
          What worries me about what you said is that it won't build up pressure with repeated pumps!? That sounds like AIR in the line, I would suggest rebleeding it, you should be able to get a FIRM pedal with a few pumps. The other thing could be that the caliper piston is not sliding outwards towards the rotor and staying there, but is fully retracting back into the caliper housing so you have to push a bunch more fluid into it before it moves far enough to again contact the rotor. Perhaps a binding piston seal or corrosion behind the seal pinching the piston...seal actually ROLLING inwards instead of allowing the piston to slide towards the rotor? JAT or two!
          T.c.
          • MPittma100
            • Aug 2011
            • 2359
            Hey Pitt,
            T.c.
            Yes, the caliper could not be staying like it should. I am guessing that there is a residual check valve in the master cylinder (like most systems have) to keep that piston from returning. However, if that was not working, the pedal should firm up after a second pump.
            Letting air in the system is a possibility, but I do distinctly remember bleeding the old fluid out until the new started. At that point the pedal was better than before but not solid like the SF. The old fluid was very weird looking. It was a red wine color? I bled the front at the same time and the fluid was in the same condition, but front has a full pull to the lever.
            I suppose that looking at the caliper is the next move after bleeding again. If it does need to be rebuilt, where would be the best place for a kit? Maybe the master cylinder should be rebuilt as well?
            MP
            K&N Air Filter
            ACCT
            EBC Front Rotors
            Mike
              • 8766
              MP
              I'd try reducing the free play some more but not so much to cause the caliper to drag, see what happens.
              • Crusty Snippets
                • Sep 2010
                • 428
                • Gabriola BC
                Brake
                What TopCat said.
                I would remove the caliper and pump out the piston. Might take many many pumps. Clean everything with the piston seal removed. Put the proper grease on the seal, anti seize on the pucks / pads and bleed it again.
                Sometimes it takes lots of pumps to get a solid pedal. Using a clear hose on the bleed screw lets you see the air bubbles, and later the lack of air bubbles.
                Time wise it makes sense to me to take it apart.
                Unkle Crusty
                • SFerinTEXAS
                  • Jun 2006
                  • 877
                  Have my rear m/c off the SF right now, the exact same symptoms. Found spooge hole clogged .Apparently it was still sorta working with just the fluid trapped in the m/c bore but would not pump up. doing a complete strip and clean tonight.
                  79SF
                  XJ11
                  78E
                  • MPittma100
                    • Aug 2011
                    • 2359
                    Clogged up master cylinder
                    I have not had one of these apart. Is this spooge hole easy enough to see? Are you going to install a rebuild kit or clean only?
                    MP
                    K&N Air Filter
                    ACCT
                    EBC Front Rotors
                    Mike
                    • SFerinTEXAS
                      • Jun 2006
                      • 877
                      I have a rebuild kit bought long ago. Intend to have it for a while longer.Lots of peeps here will advise a good cleaning(disassemble) generally cures brake issues as do I. You will be surprised at the crap build up in this stuff.
                      Not saying this is Your problem,just certain its mine. Search "spooge hole" on this site and look for the ones pertaining to the rear m/c. A complete tear down and cleaning of all the brake system parts is fair advice.
                      79SF
                      XJ11
                      78E
                        • 7861
                        • MPittma100
                          • Aug 2011
                          • 2359
                          Update
                          Removed and disassembled m/c. Noticed adjuster push rod was quite rusty and found that m/c plunger seal was leaking. M/C was almost empty. Inside was not all that dirty. Also the reservoir o-ring was broken. Have a kit on the way, will install and see if that cures problem. The bore of the m/c needs a little attention. Any suggestions on how to clean that up?
                          MP
                          K&N Air Filter
                          ACCT
                          EBC Front Rotors
                          Mike
                            • 8766
                            Looks like you found the problem. To clean out the bore, I have used a wooden dowel a little smaller than the bore. I cut a slot down the middle lengthwise a few inches and slip in some 320-600 grit paper and wrap around the dowel, then twist it in the bore. Rolled up sandpaper alone without the dowel will also work.
                            • MPittma100
                              • Aug 2011
                              • 2359
                              Finally
                              Got the m/c and caliper kits today. Noticed that m/c kit does not include the reservoir o-ring. Now I wonder why that does not come in the kit? I mean it is part of the m/c and of course the old one is split. Oh well.
                              MP
                              K&N Air Filter
                              ACCT
                              EBC Front Rotors
                              Mike
