XS1100H Vetter Fairing Question
  • mmatches1
    • Sep 2012
    • 121
    • Alberta, Canada
    It has been a while since I disassembled the Vetter fairing on my XS1100H and can't remember if there was a cover for the wiring that usually sits in the headlight cover. Is there such an animal? If not, is it important to cover these? Anyone devised something that will work?
    81H Venture - hope to ride summer 2013
    79F Cafe Racer at Some Point;
    68 CB175 Sloper - Cafe Racer
    74 KZ400 - Restoration project nightmare
    62 BSA Super Rocket - In Pieces
    72 CB100 Super Sport - Not super or sporty but fun
  • dpotter58
    • Aug 2004
    • 1835
    • Southern Maryland
    I used a couple rolls of electric tape around a qt sized zip lock bag
    1980 LG
    1981 LH
      All the front wiring plug-ins are outside and reside in a Yamaha pull-string plastic bag behind folded in headlite ears.
      • mmatches1
        • Sep 2012
        • 121
        • Alberta, Canada
        Oops - I thought someone jerry rigged that and took the headlight brackets off. Guess I have to DIY now.
          Hi Duwayne,
          That sounds like a very workable solution to replace the Vinyl pull string bag.
          • Jerry
            XS & TRUE XJ GURU
            • 3023
            • Elma, IA.
            Yes, Vetter made a 'cap' that fits inside the headlight shell. This works with the Vetter IV I have on the XJ. This combo lets the bucket stay in place, no need to remove it. I found the cap at a bike boneyard near Madison, WI and paid $5.00 for it.
            IMHO this makes a much neater install than many I have seen. I don't know if it will work with earlier Vetters or other XS11s.
            Jerry Fields
            '82 XJ 'Sojourn'
            '06 Concours
            My Galleries Page.
            My Blog Page.
            • ExcessiveBiker
              • Nov 2006
              • 60
              • Texas
              Vetter headlight bags
              Those bags are overrated. My first two Vetters did not have bags with them, just tywrap the wire bundle together, and forget it. My latest is a stock Venturer, that came with a bag from the Yam factory. I needed to check some wires up there, shortly after I got it, so the bag had to come off. Much swearing later, I got it out, fixed the wires, and the bag has been on my bench ever since. The fairing blocks most of the weather, and the lack of bag has never given me any problems with shorts or not running. Plus, it is now much easier to work on when doing mods like HID lighting.
              Don't mourn it, dump it.
              ExcessiveBiker
              81 Venturer
              81 SH
              80 MNS
              • mmatches1
                • Sep 2012
                • 121
                • Alberta, Canada
                Great stuff - thanks. I was worried that moisture would work its way into the connectors normally shielded by the headlight cover.
                  • 7621
                  Just put a bit of dielectric grease inside all the connectors. If you have an 80's Japanese car, you may remember the connectors under the hood all had grease on them. Keeps the moisture out, and the electrons in.
                  Just fill the female connector, and install the male connector. the excess will squeeze out, and seal the connection from the weather. It will NOT get in the way of the connection, as the connectors are solid when installed correctly/fully.
                  • ViperRon
                    • Feb 2011
                    • 1062
                    • Woodstock, VA
                    If you do use the bag remember to put it to where the open side is down so water will not collect in it if the bike is outside. The bag will protect the plastic connectors from elements but it is a hassle to take off and on.
                    Rodan
                    1980 G Silverbird
                    1198 Overbore kit
                    Grizzly 660 ACCT
                    Barnett Clutch Springs
                    R1 Clutch Fiber Plates
                    122.5 Main Jets
                    ACCT Mod
                    Mac 4-2 Flare Tips
                    Antivibe Bar ends
                    Rear trunk add-on
                    • mmatches1
                      • Sep 2012
                      • 121
                      • Alberta, Canada
                      Some great advice - thank you. Another problem solved!
