Idle mixture screws (and pics)
  • BillyRok
    • Aug 2011
    • 421
    • Shortsville, NY.
    I decided to replace the tiny o-rings on the idle mixture screws before putting the carbs back on the bike (thanks for the Suzuki part #s Motoman). The screws and springs came out easy but I had to fish the washers and o-rings out with a paper clip, a couple didn't want to come out. This is what I had:
    [IMG][/IMG]
    and
    [IMG][/IMG]
    You can see that the spring and washer slide onto the long straight shoulder of the screw with room to spare, but the o-ring only slides up the tapered shoulder, it won't fit over the straight shoulder with the spring and washer.
    What holds the o-ring and washer so tightly in place in the carb (a couple were hard to get out with the paperclip) if there is space on the screw between the spring/washer and the o-ring? I don't see how tightening the screw in the tower puts tension on the o-ring if the o-ring doesn't fit the screw. Just trying to make sure I put it back together correctly.
    Thanks for any insight.
    Billy
    that o-ring stretches to roll up onto the shoulder section. It then gets pushed into tapered part of the port it goes into. Which is why they look flat on top and dished on the bottom when worn in. The spring keeps pressure to hold it down in the port.
    • Yard Dogg
      • Mar 2010
      • 884
      • Tri-Cities, Wa
      While we're on the subject, does anyone know a good way to seal them without the O-rings? I'm missing a few and they are old and rotten anyway, sorry to hijack the thread.
      • BillyRok
        • Aug 2011
        • 421
        • Shortsville, NY.
        Motoman told me the o-rings are still available from Suzuki, part number is
        13295-29900. He was right, I'm looking at 4 of them now. Maybe the part number should be included in the Carb Cleaning 101 thread??
        Billy
        • GLoweVA
          • Jun 2011
          • 1957
          • Virginia Beach, VA.
          You can also get the o-ring kit from harbor freight and in it are o-rings that are the right size.
          http://www.harborfreight.com/225-pie...ent-67609.html
          Then you've also got o-rings for other things that you might need too.
          80G (Green paint(PO idea))
          The Green Monster
          Got him in '04.
          bald tire & borrowing parts
          Scarlet
          Got her in '11
          Ready for the twisties!
          81H (previously CPMaynard's)
          Hugo
          Cold weather ride
            I know several have used these for this application, but for long time durability, they need to be the higher quality Nitril variety for the enviroment they're in.
