Carb mixture screws
  • Bish
    • Mar 2013
    • 15
    • Nottingham, NULL, UK
    Carb mixture screws
    Hi , I have just fitted carb rebuild kits to my XS1100SF 79 , but when I fitted the mixture screws the old ones ranged from 2.5 turns out from fully screwed in to 4.5 turns , does anybody know the correct setting as my manual says (DO NOT TOUCH THEM) some use when your fitting new ones. Many thank Bish.
    79 SF
  • barrelguy
    • 176
    • Oliver, BC
    My manual also says DO NOT TOUCH but then says the factor default is 1 1/4 turns out.
    1980 XS 1100 Special
    Mostly stock & original
    Added Yamaha fairing (w/ 8-track!)
    Torpedo bags
    New paint (still) pending
    Stainless brake lines
    Tkat forkbrace
    Coils from Honda 1000
    Previous bikes:
    1968(?) 350 Harley Davidson
    1977 Yamaha 650
      • 8930
      Use your sync gauges to achieve the highest vacuum reading on each cylinder. First sync the carbs, then turn the #1 mixture screw in or out to get the highest vacuum reading. There will only be a slight change but you will see it. Repeat for the other 3 mixture screws> Readjust the main idle adjustment knob to keep the idle around 1100 during this process.
        I'll add a good starting point after a rebuild is about 2 turns out.
        • nzemke
          • Sep 2012
          • 179
          • Moses Lake, Wash.
          I just finished a rebuild of the carbs on the same bike and two full turns out to start was perfect.
          79F with two parts bikes (78E and a 79F). Ran it for the first season all the way through the summer. more work to do this Spring!
