brake rebuild problems
  • Foolber
    • May 2013
    • 28
    • Lincoln, Nebraska
    roger that, i had the seal on correctly in the first place, but didnt hurt to double check, so everything is back together and i did the yamabond on the reservoir. so ill reassemble tommarow and see what happenes, thanks!
    82 XJ 750
    97 YZ250
    Mitchell Peters - Pipes Racing
    Lincoln, Ne
    • Foolber
      • May 2013
      • 28
      • Lincoln, Nebraska
      ok got the front all squared away, i think it was that spooge hole. but either way didn't hurt to take it apart again to double check, except i broke the aluminum clamp/bracket while tightening the bolts so i ordered this, since his old cap was broke anyways i figure ill give him that also
      so now on to the rear again, its working but not perfectly, so i think it needs the reservoir also removed and cleaned. is there the infamous spooge hole in that one?
      82 XJ 750
      97 YZ250
      Lincoln, Ne
      • Foolber
        • May 2013
        • 28
        • Lincoln, Nebraska
        does the rear reservoir come off also?
        82 XJ 750
        97 YZ250
        Lincoln, Ne
          #34
          Yes it does.
          • Foolber
            • May 2013
            • 28
            • Lincoln, Nebraska
            #35
            awesome thanks! yea got it off and cleaned all that up again but still no pressure in the rear brake any ideas on that one, i do have a 1 piece stainless line for the rear.
            82 XJ 750
            97 YZ250
            Lincoln, Ne
            • clashpistol
              • Mar 2013
              • 66
              • Area 716 Location 14004 Western New York Buffalo
              #36
              Resolved brake problems
              I still had weak front brakes today and just did the great trick with tying down the lever and having a few Rum and Cokes (I don't know if you recommended that?). I put Teflon on bleeders as stated and viola. And as was said the mighty vac hand pump didn't do s&$t. Its weird that such a small system is so difficult to bleed. I was impatient as well. I put in a M/C rebuild once and did it again(duh) I did calipers with grease gun trick and it was phenominal (-10 spelling) Some of the bolts on the bike are the size of the Banjo Bolt (Axel pinch?) So as recommended take your time and the advice.
              Thanks again crew!!
              Clashpistol
              Previous bikes:
              1979 Husqvarna 390 CR (NEW)
              80's KTM 250XC
              I had a 80's
              490YZ
              TT500
              IT 490
              1986 600XT
              1988 Honda 350 XR
              2005 KTM 625 SMC LC4
              (?) Dnieper (Ural like) 2 WD Military sidecar rig
              I have a 2003 Honda 300 EX Wheeler
              and a 2010 Kawasaki 750 Brute Force Wheeler
              And now my XS1100SF
              "MEDUSA"
              http://s1319.photobucket.com/user/1c...Garage%20Resto
              • Foolber
                • May 2013
                • 28
                • Lincoln, Nebraska
                #37
                why do yall think im being impatient? i clearly stated above that i sat there for 3 hours pumping the front brake....thats patience. the front is fine, its the rear thats not working at all. and i still have to get to the carbs. this is a customers bike and iv had it for over 2 weeks, hes getting pissed, ****.
                82 XJ 750
                97 YZ250
                Lincoln, Ne
                  Impatient customer with a classic ole' muscle bike..............not hardly a good combo............
                  • Foolber
                    • May 2013
                    • 28
                    • Lincoln, Nebraska
                    #39
                    i agree, i would of had this done a while ago but the bank F'd up my credit card so i couldn't order his parts for 2 weeks
                    82 XJ 750
                    97 YZ250
                    Lincoln, Ne
                    • CaptonZap
                      • Jun 2010
                      • 1748
                      • Denver
                      #40
                      Sit down at the side of the bike and really look at the route the brake line takes from the MC to the caliper. It goes up and down, with places a bubble can float up to and stay.
                      If you want them gone, you have to make every part of the line slope up, so the bubbles go to the MC or the wheel cylinder.
                      The other way is to pump brake fluid through the lines faster than the bubble can float back to the high spot, which lets the fluid flush the bubble out. Take a pressure pot full of fluid, and a way to catch the overflow.
                      Do you have a way to sling the back or the front of the bike up about three feet, like from a rafter? That might help. Or, since it sounds like you are doing this commercially, you might set the front or back wheel on your lift, and jack it up that way. After an hour or so, set it back down, and if the bubble went to the wheel, bleed it one more time. If it went to the master cylinder, and you have the spooge hole open, the air should be in the reservoir, and you are good to go. CZ
                      • Foolber
                        • May 2013
                        • 28
                        • Lincoln, Nebraska
                        #41
                        yep i have a jack and a lift, ill give it a shot.
                        82 XJ 750
                        97 YZ250
                        Lincoln, Ne
                        • Foolber
                          • May 2013
                          • 28
                          • Lincoln, Nebraska
                          #42
                          can i get a picture of the rear MC's piston and seals so i can make sure they are on correctly also. the bottom seal that is closest to the spring keeps coming off my piston, not sure if it is supposed to do that or not.
                          82 XJ 750
                          97 YZ250
                          Lincoln, Ne
                          • Foolber
                            • May 2013
                            • 28
                            • Lincoln, Nebraska
                            #43
                            bump bump bump bump bump bump
                            82 XJ 750
                            97 YZ250
                            Lincoln, Ne
                              • 8796
                              07 Triumph Tiger 1050
                              • Foolber
                                • May 2013
                                • 28
                                • Lincoln, Nebraska
                                #45
                                no i meant an actual picture, thats a diagram, i can see those on bikebandit.
                                82 XJ 750
                                97 YZ250
                                Lincoln, Ne
