Battery is good but bike wont start
  • Sebastian_99
    • May 2013
    • 137
    • Florissant, COLO.
    Hey everyone, I just picked up a 79' XS-1100 Special today and it was running fine and when I pulled up to stop I accidentally stalled it out. After I stalled it it suddenly wasn't getting any power whatsoever (no lights, no neutral light, no starter trying turn the engine over, nothing). I grabbed a voltage meter from the car part store across the street and first checked the battery, it is fine. I then traced the wires to what I assume is some big relay...still getting power. All the visible fuses were fine as well. Any ideas on what the issue may be?
    I need to get this solved ASAP cause its sitting in a parking lot.
    79 SF
  • cpmaynard1980
    • Feb 2013
    • 183
    • Hampton, VA.
    Have you checked the ground connection? if the battery has power but no ground then you wont have power anywhere. You could do a continuity check between the - side of the battery and somewhere on the frame away from the battery. or run a jumper wire from the - side of the battery to another point on the frame. I ran into a problem like this when i put coated bars on one of my bikes. The electric starter wouldnt work without a jumper. just an idea. Hope it helps you.
    1979 XS1100 Special. Nicely modified.
    1977 KZ1000 needs everything!
    1971 CB750 Nice Restomod Completed
    1972 CB750 Got it going after 30 years. Getting turned into a old school bobber. Working on a title.
    SOLD-1981 XS1100H What got me on this site.
    1980ish virago 535. Room mate left it for rent money. lol.
    1980 XS850 almost stock 20k miles.
    1979 XS750 Parts bike no title.
    1979 XS750 Cafe running,someone else can enjoy it.
    RIP-1980 XS850
      could be the main fuse, or the key switch. If it has the factory fuse box, it is not uncommon for the fuse to look fine, but the end is actually loose, or the clip is not tight and conducting.
      • Sebastian_99
        • May 2013
        • 137
        • Florissant, COLO.
        I can try that out. How would that explain it working and ten suddenly crapping out though?
        79 SF
        • graybird78
          • Apr 2003
          • 360
          • council bluffs iowa
          main power fuse .not in fuse box.try under left side cover.its by itself
          when you want something bad enough, don't let anything stand in your way, and don't take "no" for an answer. EVER
          graybird78
          80 sg (old faithfull)
          • Sebastian_99
            • May 2013
            • 137
            • Florissant, COLO.
            I checked the main fuse and tested it on the voltage meter and it was good to go. The contacts were a bit corroded but nothing too crazy. What is the key switch and where/how do I make sure it is ok?
            79 SF
            • Sebastian_99
              • May 2013
              • 137
              • Florissant, COLO.
              At the risk of sounding like a complete fool but what does it look like? Any chance you have a picture? That would help me immensely.
              79 SF
                • 8798
                Your 79 has the main fuse in the fuse box under the RH cover, only the 80-81 has it seperate under the left. It should be a 30 amp fuse.
                Edit: You can check the connector for the key switch in the headlight bucket, red, brown and blue wire. The connector can melt and cause power loss.
                  on the 79 the main fuse is in the fuse panel, its the 30 amp fuse. Key switch = main switch, where you put the key and turn to ON to power the bike.
                  Highly recommend to check for power at the wires where they go into the fuse clips. the clip may not get power to the wire.
                  If you have power at the tan wires going to your fuses, the key switch is probably not the issue.
                    C|ould it be as simple as knocking the "Kill Switch" on the handle bar ?
                    Try wiggiling the wires that go to that switch too.
                    • Newbee
                      Truly XSive (Deceased)
                      • Jul 2011
                      • 160
                      • Whitby Ontario, Canada
                      won't start
                      You say no power you didn't hit kill switch by accident?I also have coated bars which I have to sand every year or I don't get anything even after need to twist starter button housing to make contact.
                      • Sebastian_99
                        • May 2013
                        • 137
                        • Florissant, COLO.
                        I just stopped by to check those fuses...no luck. They are good though the main one is a bit corroded on the inside. Unfortunately I couldn't just swap them becyase the part store was closed already. As far as the wiring out of the key switch, it seems fine. However I peeked under the seat and there is a melted connector there with green wires. Might that e the issue? On another note how do I even pop the seat up?
                        79 SF
                        • Sebastian_99
                          • May 2013
                          • 137
                          • Florissant, COLO.
                          I apologize in advance...electrical issues are beyond me.
                          79 SF
                            If the bike still has the OEM fusebox, check for 12v power to ground at both red wires connected to the 30 amp fuse. If good, then turn on the key and check for power at the brown wires at the top of the box. If no power, then the ignition switch or it's plug has failed.
                            If the wiring has been hacked at all, then you'll have to dig out the diagram and start tracing....
                              This is going to sound weird, but, don't check the fuse, check the contacts on the outgoing side with the meter. Check the volts to ground. I am betting the fuse and/or connectors are good enough to pass a continuity check but cannot pass enough voltage to run things.
