Sorry if this has already been addressed, but the search function isn't working on my phone. Has anyone used the rh control from a zrx 12? I'm trying to use it with the zrx carbs and I am getting stuck on the wiring. What wires connect to each other from the starter button and kill switch to the xs11s wiring? Any help would be much appreciated
zrx rh controls
zrx rh controls
1979 xs special, just finished the top end rebuild and then i still have lots of work.
progress thus far...
http://s1268.photobucket.com/albums/...t=IMAG0202.jpg
"If it runs bad, it's usually the carbs. If the tires go flat, I suspect the carbs. If the wind blows the bike over, the carbs were probably to blame. If my wife yells at me about something, I tell her to talk to the carbs" -IncubusTags: None -
You might have slightly different color wires, but it should be the same idea
Hope that helps.79 SF 3H3 Engine, 145/45 Mikuni Jets, El Cheapo Pod Filter Mod w/ EMGO Pods, Coil Repower w/ Dyna Coils, Accell Wires and Side Gapped Plugs, 78 Mech Advance, 4-2 Turnouts
