bike wont start, still
    • 9981
    Originally posted by DGXSER
    If your SG only has three wires, two red/white and a blue/white, then that switch is off a 78-79 model.
    I didn't open the sheathing, I just felt what I thought was 3 wires through the sheathing.
    • Throop25
      • May 2013
      • 46
      • ludingron mi
      okay so yes thats what i was saying, in the off position i have 12 volts on one wire nothing everywhere elese when i click the switch to run i lose that 12 volts to a gremlin, secondly where do i get a new switch, im gonna take this one apart and clean it but i dont know where my power is going when i turn it to the on position
      81 eleven special
      • mikubuilder
        • Jul 2011
        • 548
        • Westland, Mich.
        Throop, look at the diagram in post #29, the kill switch, in on position should have continuity from one red/white to the other red/white, and your start button(when pressed) should have continuity to ground(in handle bar, I presume)
        Nick
        1982 Virago 750 (it's alive!)
          #34
          Ok, so where are you measuring at? Moving the switch almost can not lose the power that was there on the red/white wire from the fuse. So it almost has to be internal to the switch.
          You can find a replacement switch HERE
          Be careful cleaning the switch is there more than a few small components like springs and c-clips and small metal balls that will search out remote crevices of your work area that you may never discover. DAMHIKIJK
            #35
            ...but i dont know where my power is going when i turn it to the on position
            How are you checking for power? To check voltage, one meter lead has to go to ground. If you're checking between the two wires, closing the switch takes away any difference of potential and the voltage will 'disappear'. If you are checking to ground, then chances are very good that you have a poor connection in a plug or connection or a partial short to ground.
            Go back and carefully read this: http://www.xs11.com/forum/showthread.php?t=35339 until you understand it, then check each connection starting at the fusebox.
            There are NO shortcuts when checking electrical....
            • CaptonZap
              • Jun 2010
              • 1748
              • Denver
              #36
              There are NO shortcuts when checking electrical....[/I][/B]
              Aww Steve, all I want to do is ride this thing. Just tell me what is wrong, and how to fix it, quick. CZ
              • Throop25
                • May 2013
                • 46
                • ludingron mi
                #37
                so i found my gremlin, corrosion, the plug for the killswitch , thanks alot steve and everyone else who put up with my newb self..thanks guys ooks like ill make it to the blessing after all
                81 eleven special
                  #38
                  Cool, good job finding the problem!! Now, I would highly recommend you not stop at that one connector, take the next rainy day and pull the tank and seat off, the headlight out, the side covers off, and start at one and working to the other cleaning each and every connector on the bike. And especially the ones hiding behind the fuse box mount.
                  • Throop25
                    • May 2013
                    • 46
                    • ludingron mi
                    #39
                    that is my plan for tommorow, right after i take it for a ride
                    81 eleven special
                    • CaptonZap
                      • Jun 2010
                      • 1748
                      • Denver
                      #40
                      Excellent! While you are out riding, stop in at your favorite parts store, and get a tube of this stuff;
                      http://www.napaonline.com/Catalog/Ca...824_0361152134
                      After you clean the contacts, apply some grease to both halves, and plug them back in. You will be good for years of worry free connections.
                      CZ
