bike wont start, still
The list changes. -
okay so yes thats what i was saying, in the off position i have 12 volts on one wire nothing everywhere elese when i click the switch to run i lose that 12 volts to a gremlin, secondly where do i get a new switch, im gonna take this one apart and clean it but i dont know where my power is going when i turn it to the on position81 eleven specialComment
Throop, look at the diagram in post #29, the kill switch, in on position should have continuity from one red/white to the other red/white, and your start button(when pressed) should have continuity to ground(in handle bar, I presume)Nick
1982 Virago 750 (it's alive!)
1979 XS 11 F, Windjammer IV, Samsonite luggage cases(another rescue)Comment
Be careful cleaning the switch is there more than a few small components like springs and c-clips and small metal balls that will search out remote crevices of your work area that you may never discover. DAMHIKIJKLife is what happens while your planning everything else!
78 XS750Comment
Go back and carefully read this: http://www.xs11.com/forum/showthread.php?t=35339 until you understand it, then check each connection starting at the fusebox.
There are NO shortcuts when checking electrical....Fast, Cheap, Reliable... Pick any two
Cool, good job finding the problem!! Now, I would highly recommend you not stop at that one connector, take the next rainy day and pull the tank and seat off, the headlight out, the side covers off, and start at one and working to the other cleaning each and every connector on the bike. And especially the ones hiding behind the fuse box mount.Life is what happens while your planning everything else!
78 XS750Comment
Excellent! While you are out riding, stop in at your favorite parts store, and get a tube of this stuff;
http://www.napaonline.com/Catalog/Ca...824_0361152134
After you clean the contacts, apply some grease to both halves, and plug them back in. You will be good for years of worry free connections.
CZComment
