Leaking Petcock-81 eleven special
  • Throop25
    • May 2013
    • 46
    • ludingron mi
    so i pulled the gas tank off and found the fuel lines had zip ties on them, was kinda in a hurry cause i was leaking gas in the garage, anyone have a diagram for the fuel lines? or advice on how to stop the leak
    81 eleven special
    The hoses #3 go to the tee fitting between the carburetors. #2 is a vacuum line that goes to the tap on the left most intake manifold.
    You'll have to explain better what's leaking. If everything was hooked up and fuel was leaking, you'd have to have at least one leaking petcock, a leaking vacuum shutoff, and one or more leaking float valves.
    This kit will help you rebuild the two petcocks and vacuum shutoff. (spider valve)
    XS1100 SPECIAL PETCOCK KIT XS1100SF XS1100LG
    The same vendor is a good source for a lot of the carburetor parts if you need them. That's been my experience.
    • Throop25
      • May 2013
      • 46
      • ludingron mi
      its leaking right out of the switch, then when i took the tank off it just acts like it wont shut off, it was leaking out and dripping down to the exhaust
      81 eleven special
        That kit I linked to will fix it. In case you need it, here's a little help.
        Rebuilding Yamaha Vacuum Operated Fuel Valves (Petcocks.)
        I realize the petcocks on your bike aren't vacuum, but the info could be useful just the same.
        • Throop25
          • May 2013
          • 46
          • ludingron mi
          said petcock is also super hard to turn
          81 eleven special
          • Throop25
            • May 2013
            • 46
            • ludingron mi
            okay cool man i appreciate it,
            81 eleven special
