Carb passage plugs - 1981 xs1100h - running rough
  • mmatches1
    • Sep 2012
    • 121
    • Alberta, Canada
    I spent most of the day with Rasputan yesterday trying to tune my carbs and it runs rough and backfires. As per the schematic I installed passage plugs but are wondering if that may be a problem. The two main passages are not linked by a hole and as discussed on another thread. There were no plugs when I first opened the carbs. Also, I jetted them 115 in the center and 110 on the outside when the original was 110 on all four. Also discovered that I am missing the small washers and rubber seals on my idle adjust screws. Any thoughts?
    81H Venture - hope to ride summer 2013
    79F Cafe Racer at Some Point;
    68 CB175 Sloper - Cafe Racer
    74 KZ400 - Restoration project nightmare
    62 BSA Super Rocket - In Pieces
    72 CB100 Super Sport - Not super or sporty but fun
    Your carbs do not use the plugs. Get those out of there. The jetting will make it tune different but it should run and tune. Without the washers and o-rings you mix screws will not work properly. You can order new screws, or I have bought washers and ground them down to size. I have the nitrile o-ring kit from HF that had the right size in it.
      • 8061
      +1. What he said! You are sucking air at the idle adjust screws. There should be no plugs over the idle jet.
      • donebysunday
        • Oct 2012
        • 1737
        • New Berlin, Wi.
        Use a bright flashlight to look down into the idle mix holes to make sure those washers and little seal are not still stuck down in there ? If they are you can remove them with a paper clip bent and shaped to just a little hook on the end.
        If they are gone Radio Shack sells a bag of small washers, find they ones that fit over the mix screws and use your dremel tool with the cut off wheel holder, center the washer on the tool and use a file to turn them down.
        Buy a foot of weed whacker fuel line and cut a O-ring seal off the end. Takes a few tries but will work.
        76 XS650 C ROADSTER
        80 XS650 G Special II
        https://ibb.co/album/icbGgF
        80 XS 1100 SG
        81 XS 1100LH/SH DARKHORSE
        https://tinyurl.com/k6nzvtw
        AKA; Don'e, UD, Unca Don'e
        • jwhughes3
          • 2798
          • Home of the Alamo
          The nitrile oring kit from Harbor Freight is like $3 and has orings for the mixture screws, the needle seat inserts, the drain plug orings, and various other things.
          John
          '81 XS1100H - "Enterprise"
          • mmatches1
            • Sep 2012
            • 121
            • Alberta, Canada
            I wondered what HF was. Have heard that the original parts are available from Suzuki but are very expensive. Evidently model plane shops have a good selection of small washers.
            • mmatches1
              • Sep 2012
              • 121
              • Alberta, Canada
              Do you have a link to these parts or part numbers? Is it Harbour freight tools? Thanks.
                • 8061
                mmatches1,
                OEM parts can be purchased at a discount.
                www.partzilla.com
                www.yamahapartshouse.com
                www.ronayers.com
                If you search, there are more.
                  Yes, HF = Harbor Freight.
