What to do about new jugs
  • DRedel
    • Mar 2012
    • 119
    • New York, N.Y.
    Hello all. I was seeking help last year about motor problems. Well I took the motor down and found that I had bent two intake valves. But I did not burn a whole in a piston like I thought and the rings were not stuck. So now what to do. The cylinder walls are pitted so I believe what I need is the whole set with the pistons in the jugs. Maybe the 150 big bore on ebay? But the best price I have found is 400 to bore it out. Do I have any other options? Cheaper is better. And if jugs with the pistons in it is what I need does anyone have anything they could part with? Thanks. Dustin
  • WMarshy
    • Apr 2009
    • 2402
    • Mexico NY
    You can get entire running engines for cheaper than what it will cost to repair yours... sometimes they come with the rest of the bike intact too!
    If ya figure $150 for the BB kit, $400 for boring, $75 for engine gasket kit and new valves at $35 a pop ... your into about 7 bills already.
    BTW, you can get a used jug and matching pistons off ebay for relatively cheap (comparatively) but then have no idea if they really came from a healthy motor (do you really trust the seller). Complete heads can be found cheap too.
    Other option is to look in the parts section of the forum and have some confidence that your not getting junk parts or robbed on price...
    Did the bike run prior to the bent valves or is this a project you picked up? Depending on the pitting in the cylinder you mught want to pick up some used valves from the forum and just run the thing. Take some compression readings after its back together before you decide to do all that work... just my $0.02
    '79 XS11 F
    Stock except K&N
    '79 XS11 SF
    Stock, no title.
    '84 Chevy K-10 "Big Blue"
      Send a PM to member Andreas, tell him what you need, his prices are very reasonable. He is the used parts guy.
      • Yard Dogg
        • Mar 2010
        • 884
        • Tri-Cities, Wa
        Have you tried honing it yet? My XJ was pitted from being seized. I was able to hone 0.002" off and the pitting was removed. The bike runs great no smoke. I didn't think honing would be enough, but this is nice dense Japanese steel we're dealing with here. The pitting wasn't deep, it just looked that way.
        • WMarshy
          • Apr 2009
          • 2402
          • Mexico NY
          Adding 0.002 clearance to a cylinder seems excessive to me and might take it out of spec. What did you do for rings?
          '79 XS11 F
          Stock except K&N
          '79 XS11 SF
          Stock, no title.
          • Yard Dogg
            • Mar 2010
            • 884
            • Tri-Cities, Wa
            It's still in spec. You have to make sure you use good instruments for measuring while you do it to keep it from getting out of round. Since the rings are chrome molly and have a lot more miles on them, I reused them. No point in throwing away good money.
            • Lunatic
              • 200
              • Watertown SD
              Free engine
              If you can figure out a way to get the engine from here to there, I have an engine here you can have. RUNNING when taken out of the bike over the winter. Located in Watertown SD. stored indoors in heated garage. I have no need for it, but hate to just send it to the recycler. If no one takes it, eventually I'm sure I'll just have it melted down.
                What to do about new jugs. Another provocative subject line! :-)
                • DRedel
                  • Mar 2012
                  • 119
                  • New York, N.Y.
                  Thanks everyone for your suggestions. Maybe I can get away with honing. I knew of a ruff parts bike sitting out on the woods so I grabbed it maybe something can be salvaged. Hopefully intake valves. Maybe cylinders.
