Does anyone know how to get piston rings from Hastings or perfiect circle. Where can I get the specs I need to give them to get what I need? I have an oportunity to get another XS11 for my wife. The guy did the bottom end about a year and a half ago. Seems it will need a valve and ring job. Low compression. Hopefully it will not need boring, then I'll have to go big bore.
79 xs piston rings
Some time ago someone did the research on Perfect Circle, I think it was...on the old yahoo list. Had part numbers for the compression and oil rings. I don't have access to the old list from work, will have to see if I can find it when I get home.Jerry Fields
'82 XJ 'Sojourn'
'06 Concours
My Galleries Page.
My Blog Page.
"... life is just a honky-tonk show." Cherry Poppin' Daddy Strut -
I saw in a previous posting that the Yamaha numbering system is basically like this:
The first three positions represent the bike model, in my case 2H7 for xs1100 standard and the rest represent the part. While looking for the rings for this bike I found the part number to be
3J2-11610-00-00 which I guess replaced 2H7-11610-00-02
My question is is this ring set number below the same ring set on this 79 xs11?
1TA-11610-00-00 Ring set 1998 XV1100SKC VIRAGO 1100 SPECIAL
I have found sites that sell ring sets and valves for golf carts and outboard motors that use the same last eight part numbers.
Example:
OEM#JN6-12111-01 Intake Valve
OEM#JN6-12121-00 Exhaust Valve
These valves are for a golf cart at http://www.powellsequipment.com/yamahaengine.htm
Are these the same as 1J7-12121-00-00 and 1J7-12111-01-00 which replaced 1J7-12111-00?
I am trying to find every way I can to locate parts for these old XS11's.79 XS1100 f (BIGDOG)
80 XS650 Special
85 KAW 454 LTD
Dirty DanComment
As I mentioned in an earlier post, I am looking for the specs for the ring set on a 79 xs11. If anyone can help me find them or send me in the right direction, I would greatly appreciate the assistance.
Thanks a ton
Dan79 XS1100 f (BIGDOG)
80 XS650 Special
85 KAW 454 LTD
Dirty DanComment
