Rear tire cable opperation?
  • Foolber
    • May 2013
    • 28
    • Lincoln, Nebraska
    can anyone give me a detailed description on how to use this rear tire cable thing, my customer has all the original tools from yamaha still in the original yamaha bag
    just to get you up to speed, i was refered to this forum from XJbikes.com were i am an avid member. I own an 82' XJ750j. (among other yamaha dirtbikes :P) this is my first XS i have ever worked on and seen in person (beautiful i might add) im doing an entire brake job on this XS1100, front and rear, (lines, MC's, and calipers) i have frozen calipers all around, the rear is just not wanting to come off with out me taking off the tire. the 2 front calipers are off and pistons freed and cleaned, just waiting to take off the rear and move on from there.
    82 XJ 750
    97 YZ250
    Mitchell Peters - Pipes Racing
    Lincoln, Ne
    • Foolber
      • May 2013
      • 28
      • Lincoln, Nebraska
      damn i love yamaha's! that worked perfectly (what else would you expect from yamaha ) THANKS DUDE!
      82 XJ 750
      97 YZ250
      Lincoln, Ne
      • jwhughes3
        • 2798
        • Home of the Alamo
        Post pics ya damn Foolber!
        John
        '81 XS1100H - "Enterprise"
        • Foolber
          • May 2013
          • 28
          • Lincoln, Nebraska
          dont see how to upload them
          i know how to insert a link for them but i dont have them on a webpage. and prob wont
          82 XJ 750
          97 YZ250
          Lincoln, Ne
          • sparkfly88
            • Mar 2013
            • 585
            • CedarKey FL
            What is this silly little cable device? Suspension limiter?
            79F
            "Excelsior"
            Honda gl1100 handlebar
            Vetter IV fairing with speaker system
            OE headers,Jardine slipons
            Hid headlight 6000k
            Stock jets
            Shinko 712 F & R
            Oe hardbags and luggage rack
            TC fuse block
            K&n filter with oe airbox
            Raptor 660 Acct
            • jwhughes3
              • 2798
              • Home of the Alamo
              Exactly! Limits suspension when removing tire.
              John
              • sparkfly88
                • Mar 2013
                • 585
                • CedarKey FL
                On only the early bikes?
                Or do I need to rig something up when I plan to do my tires...
                79F
                "Excelsior"
                Hid headlight 6000k
                Stock jets
                Shinko 712 F & R
                TC fuse block
                Raptor 660 Acct
                  It is to lift the rear swingarm up so the axle clears the exhaust. It is only an issue ont he Standard models. The Specials exhaust stops short of the axle.
                  • Foolber
                    • May 2013
                    • 28
                    • Lincoln, Nebraska
                    Yea it's really a nifty tool! Update - All calipers off and clean. Removed rear MC but haven't disassembled, already knew it needed to be rebuilt. So gonna take it apart when I get the kits in. Same with the front MC. Gonna go with the 1 piece line for the rear, and all normal up front for everything.
                    Ill be taking the carbs off soon, he said he thought the carbs were clogged at 1 point in time so he took an air compressor and blew air threw one of the fuel line. This I am assuming bent the tang on the floats and is why he's getting gas in his oil. But either way I will go through them and order him a new intake boot kit. Do these intake boot bolts have the same prob with seizing as the XJ's? If so I know my cordless impact will work great and a little bit of heat from the torch. (been threw this with my XJ, snapped 2 before grabing the impact)
                    And also how do I change my sig, and location lol. Didn't see it in the account area
                    82 XJ 750
                    97 YZ250
                    Lincoln, Ne
                      If this is a 78-79 model (or the carbs are the older model carbs) they will have brass floats. It is entirely possible he collapsed a float or more pushing the compressed air in the fuel line like that.
                      I have removed the boots form a couple of pretty well neglected XS11s, one sat out in a farm field for a couple years. Never had any problem with seized bolts.
                      If you look in the dark blue line toward the top of the page you will see the "User CP" link, go in there and then select "Edit your details". Scroll down to the additional information section and you will see where your location is listed, you can change that there. Now look at the left hand list under "Settings and Options" Second link down is "Edit Signature".
                      • tcoop
                        • Nov 2009
                        • 793
                        • South Weber, UT
                        pics
                        Four those who are interested in what it looks like...
                        http://xjbikes.com/Forums/viewtopic/t=42450.html
                        It is a nice looking bike.
                        Ty
                        78 XS1100E - Now in Minnesota
                        80 XS1100LG - The Punisher
                        82 XJ1100 - Daughter's Bike
