pilot jet size question..........
  • oldnortonrider
    • 448
    • Fayetteville, ARkansas 72701
    I'm in the process of rebuilding my carbs ~~ 3rd time in about 20 years ~~ 10 years since last rebuild. The carb kits that I've got are from georgefix (eBay), and are the best quality out there IMO (K&L). I wasn't able to find the K&Ls available, and for the right price, for the 78 or 79 carb types with the 42.5 pilots; so these came with the "45" size. They're 6 hole and the ones that are still in my carbs before rebuild and disassembly start, are 42.5 size (also 6 hole type) pilot. The machine that I've had for 21 years (daily ride) is an 81 Special; the set of carbs that are the "earlier type" with the brass floats et al, had been installed by PO. I have a separate , extra set of carbs; also 79 year; same type carbs as the ones I'm about to rebuild. My question is ~~ if I install the new "45" size pilots, instead of re-installing the "42.5" size pilots ~~ wondering what performance change I might expect? Curious if there's anybody out there , riding around with the "45 pilots" I am also installing new carb boots; they definitely look top OEM type quality; that I also got from georgefix. I'm going to get the Morgan Carbtune to synchonize with this time, although I still have the MotionPro "mercury-type" (hadn't used it since last carb rebuild on this machine)..................
    JCarltonRiggs
    The '78 came with 45 pilots and 210 air jets.
    • oldnortonrider
      • 448
      Ok; thanks for the input ~~ reminded me to look here~~>http://www.xs11.com/forum/showthread.php?t=73
      JCarltonRiggs
        That table is not correct though because it does not show the 210 air jet along with it.. I think you probably need the 210 air jet along with the 45 pilot jet.
          • 8796
          I run the 45 PJ with the 180 air jet in my 79, no problems, bike runs strong, 40 mpg. YMMV. I have 4-1 exhaust and drilled airbox/K&N.
          • oldnortonrider
            • 448
            These new K&L kits that have the 45.0 pilot, came with new 180 air jet.
            JCarltonRiggs
              • 8796
              The 45's should be fine, worst case scenario, switch back to the 42.5's.
              • MPittma100
                • Aug 2011
                • 2359
                Pilots
                I went to the 45 pilot and 210 main jets in a 79 Special that had the smaller 42.5 and 180. I like the performance of the bigger jets. I agree with bikerphil that the 45 pilot and 180 jets would be just fine as well.
                I lost maybe 3 mpg after the swap, but like I said, the performance/throttle response is better. If I were to change again I would likely go back to the 180 mains and keep the 45 pilots.
                The later smaller jets were mainly considerations for less "better" emissions required by the US.
                MP
                1981 XS1100H Venturer
                K&N Air Filter
                ACCT
                Custom Paint by Deitz
                Geezer Rectifier/Regulator
                Stebel Nautilus Horn
                EBC Front Rotors
                Limie Accent Moves On In 2015
                Mike
