Dreaded carb issues...
  • troubled1
    • May 2013
    • 20
    • Springfield, OR.
    I recently have been introduced to the world of the xs1100 carb cleaning and have noticed that you very knowledgeable enthusiasts have often said steer clear of non-mikuni mains and pilots. I have just ordered four kits from Georgefix.com as his kits come with all that is needed for the 1980 cv34 carbs on the "widder" but looks like I may end up reusing my old mains instead. I know the pilots are 42.5's but with what I'm running (4\2 headers and six pod filters...my old mains may still work? Widder was not wanting to fire cold but once started she popped through the carbs til warm. Leaked gas on the floor and was flooded before I could even crank her over. Upon inspection and clean up I notice emulation tubes corroded and float needle seats the same. I will be changing the oil to rotella t 15w40 and need to know if I should put them back together with jets from the kits or old ones? Thanks in advance guys
    80 SG "Black Widder" chop
  • tarzan
    • 1700
    • Chandler,Az.
    After cleaning you're old jets up, inspect them and see what condition they are in and if they are the correct and original jets. If they are, then I would reuse them. If they are damaged, then replacement would be a good option.
    80 SG XS1100
    14 Victory Cross Country
      • 9980
      +1. Jets don't wear out they just get destroyed by fools with tools.
      All you really need to overhaul these carbs, unless something has been intercoursed up by a PO or...............you , is gaskets and occasionally float valves.
      The key is in the CLEANING.
      • WMarshy
        • Apr 2009
        • 2402
        • Mexico NY
        You may not need the rebuild kits, your problem might be solved from a good carb cleaning. I would start with a thorough cleaning first...
        P.S. You have to have leaky petcocks as well as leaking float needle valves to cause the dreaded gas in oil problem...
        '79 XS11 F
        Stock except K&N
        '79 XS11 SF
        Stock, no title.
        '84 Chevy K-10 "Big Blue"
        • troubled1
          • May 2013
          • 20
          • Springfield, OR.
          The mains look OK and after reading all the horror stories about these carbs and the PO issues with forcing parts I was extra careful about the tear down. The PO had mangled the pilots up a bit but I was able to remove the pretty easy but wouldn't dare a reinstall of them. The emotion tube threads did suffer a bit as they were very resilient. Diaphragms and slides are in good shape so I think I'm OK there. I sprayed them with silicone and put in individual sandwich bags til reinstall. Pinesol soak and carb cleaner/air blasted all passages and ports. one thing I'm not sure of because I get mixed info on it is the actual float height of these carbs. You guys in my honest opinion, are a mountain of knowledge on these bikes and without ya, I'd be screwed for that I say cheers to you
          • troubled1
            • May 2013
            • 20
            • Springfield, OR.
            Not sure but the petcock on my tank was left open...little gas smell in the oil fill hole. The widder has a Harley tank and no octy but does have inline filters to which I'll just change the oil for reassurance. This old girl loves her fresh blood does anyone know the best place for a oil filter and brand?
            • troubled1
              • May 2013
              • 20
              • Springfield, OR.
              Also when I owned my fj1100 there was a guy who made billut spin on oil filter adapters for that bike and worked great...anyone know of any for these bikes?
              • tarzan
                • 1700
                • Chandler,Az.
                If you have the original carbs.Float height will be 23mm
                80 SG XS1100
                • WMarshy
                  • Apr 2009
                  • 2402
                  • Mexico NY
                  23mm is the spec for an 80... See this tip...
                  You can use a set of calipers if you have them or pick up one of these...
                  See post #13 for brands of filters with #'s.
                  '79 XS11 F
                  Stock except K&N
                  '79 XS11 SF
                  Stock, no title.
                  • troubled1
                    • May 2013
                    • 20
                    • Springfield, OR.
                    You fellows I must say are absolutely amazing folks...I'm sure I'll have many ?'s to come but for right now I'm very content. Thank you for being good people and helping folks new to this world of the xs's like me. You definitely are a credit to this forum and riders everywhere... cheers
                      I will add to the info that you definitely will want to replace the float needle valves and seats with the ones from the kits you get.
                      As to the jets, I can speak from experience that the jets you get in kits from Georgefix will work well. So if you think your jets are buggered up and might not be an easy removal next time, do not worry about using the jets he sends you.
                        • 9980
                        Or you can get just the jets you need HERE.
                        • troubled1
                          • May 2013
                          • 20
                          • Springfield, OR.
                          Thank you gentleman... much appreciated
                            Check your PM(private messages). Passing thru your city tomorrow....
                            • troubled1
                              • May 2013
                              • 20
                              • Springfield, OR.
                              I have sent a pm to t.c. asking him to change my location... I live in Springfield Or. But as he had created my profile, it says Phoenix Ar. Thank you though Brant cheers to you mate
