Xj/xs top tree swap?
  • xjeleven87
    • Apr 2013
    • 28
    • New York, NY.
    I want to put normal handlebars on my xj, can I swap out the top tree clamp with an xs of the same year?
    82 XJ11
    Should be able to use one off the 79-81 Special. You'll have to somehow close off the air holes on your fork tubes and figure out how to bolt the gauges on. Definitely not a simple swap.
    • xjeleven87
      • Apr 2013
      • 28
      • New York, NY.
      Thanks man. I just ordered some handle bar clamps off an xs750. I read on here that others have been able to swap them out with the mounts on the xj. I hope they're right!
      82 XJ11
        Sorry to say but the fork stanchion diameter is smaller (35MM) on the 750, the 1100's have 37MM diameter upper fork stanchions.
        • xjeleven87
          • Apr 2013
          • 28
          • New York, NY.
          Is there any way around this?
          82 XJ11
            Yes, get a upper tree of an XS1100 Special, any year, 79-81.
            • xjeleven87
              • Apr 2013
              • 28
              • New York, NY.
              -Will these work?
              82 XJ11
              • xjeleven87
                • Apr 2013
                • 28
                • New York, NY.
                Or these?
                82 XJ11
                  Send a PM to jrobertfox; he's got one for sale.....
                  • Yard Dogg
                    • Mar 2010
                    • 884
                    • Tri-Cities, Wa
                    The air holes will be fine with the xs11 special top clamp. I did the same thing to mine, no difference. You just have to use the xj headlight holders that fit over the fork tubes because they hold up the linked air system on the xj forks.
                    • Yard Dogg
                      • Mar 2010
                      • 884
                      • Tri-Cities, Wa
                      The XJ gauge pod mounting bolts are narrower than the special top clamp mounting holes. You can remove the metal bushing sleeves from the special clamp and then use fender washers and nylon lock nuts to bolt the gauges on. It will clamp down snug enough. If you want to do it better and use the metal sleeves, then you will have to make some custom offset rubber bushings.
                        The first one you posted is for a Standard, Those will not give you the right geometry. The second one is from a Special or Midnight Special and would work.
                        I have a set of TTrees from a special sitting in the garage. IF your still looking send me a PM we can figure out a deal.
                        • Jerry
                          XS & TRUE XJ GURU
                          • 3023
                          • Elma, IA.
                          The "normal" bars on an XJ are adjustable for width and height. Some folks do not recognize this. Yep, they are square which is a problem for some things, but I would try adjusting the stock XJ bars before I tossed them out. They are the most comfortable bars I've ridden behind. Mine are one bump higher than center and one bump wider than center.
                          Jerry Fields
                          '82 XJ 'Sojourn'
                          '06 Concours
                          My Galleries Page.
                          My Blog Page.
