Can I use this aftermarket starter solenoid?
  • jrobertfox
    • Sep 2012
    • 71
    • Baltimore, MD
    http://www.jegs.com/i/JEGS+Performan...10301/10002/-1
    It seems pretty basic, Jegs model, I'm only concerned about this part: "WARNING! This solenoid DOES NOT use suppression diodes. Use of this solenoid on vehicles with Engine Control Computers will result in permanent damage to the computer/processor."
    I'm replacing the stock because of where I want to mount it, and it's the same cost to just get an aftermarket one or machine a bracket.
    Are there others that people would recommend?
    '79 XS1100 Special "2-Up Cafe"
    Never Stop Building
    Custom fabrication. Bespoke furniture. Clean code. An obsession with the well-made.
    neverstopbuilding.com - Facebook - YouTube - Instagram
  • DAVINCI
    • Jan 2011
    • 1048
    • Cedar Mountain, NC
    You could use it, or get one that fits at Mikesxs.net, Part #40-2461. They come up on ebay, too. Oh nevermind, I actually read what you wrote.
    Go ahead and use it.
    • spayne83
      • Jan 2013
      • 159
      • Campbell, CA.
      This is the one that I used:
      http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
      It works with the existing wiring and comes with a bracket to mount it.
      79 SF 3H3 Engine, 145/45 Mikuni Jets, El Cheapo Pod Filter Mod w/ EMGO Pods, Coil Repower w/ Dyna Coils, Accell Wires and Side Gapped Plugs, 78 Mech Advance, 4-2 Turnouts
        That's your basic 50-70s Ford starter solenoid and won't work with the XS wiring. The reason it won't work is it doesn't have a 'ground' terminal for the coil, getting that through the mount/chassis. The XS solenoid coil is wired with an always-hot supply wire, the starter button supplies the ground path.
        The two small terminals you see on the Ford solenoid are 'start' and 'ignition' (identified with S and I). The S terminal operates the solenoid, the I terminal becomes a 12V supply when the solenoid is closed to bypass the ballast resistor.
        • DAVINCI
          • Jan 2011
          • 1048
          It can be used if he fabricates the proper isolating mount.
            The other thing is I don't think he realizes just how big that solenoid is; it's about twice the size of the OEM unit....
            • jrobertfox
              • Sep 2012
              • 71
              • Baltimore, MD
              I went with the suzuki model mentioned above. Thanks for the help folks!
              Never Stop Building
              • ViperRon
                • Feb 2011
                • 1062
                • Woodstock, VA
                I would have used this one http://www.ebay.com/itm/Yamaha-XS110...pt=Motorcycles
                Rodan
                1980 G Silverbird
                1198 Overbore kit
                Grizzly 660 ACCT
                Barnett Clutch Springs
                R1 Clutch Fiber Plates
                122.5 Main Jets
                ACCT Mod
                Mac 4-2 Flare Tips
                Antivibe Bar ends
                Rear trunk add-on
                • Yard Dogg
                  • Mar 2010
                  • 884
                  • Tri-Cities, Wa
                  Yup, I just grabbed one off of e-bay. Mine fits everything from 4 wheelers to street bikes. The wiring plug is the same too.
