Today when coming home the bike was vibrating. Don't know how to explain it, but i will try. When applying throttle, the vibration was a harder vibration. At idle, or at higher rpm's it is more of a milder, although faster vibration. If i pulled the clutch in and coasted, the vibrations were gone. That told me it was probably not the rotation of a tire, but in the engine. When i got home, i started it, and took the rpm's up. There was a lot of noise coming from the front, or top of the engine. The question would be, can a cam chain cause this? I suppose it could. I jus put the auto tensioner on about last Novenber. That is about 3200 miles. Any ideas on what or how to check for this damn thing?
Bad vibrations
Bad vibrations
1980 XS1100LG Midnight
1991 Honda CBR1000F Hurricane
A cold beer and another one!Tags: None -
Did you run it through the RPM's when you were coasting?
Ride safe,
LarryInventor of the YICS Eliminator. Want one? Get it here.
82 XJ1100
80 XS1100G (Project bike)
64 Yamaha YA-6
77 Suzuki TS-185
See it here... http://www.youtube.com/watch?v=cBYT4C9_6AcComment
I did Larry. Whenever i brought the rpm's up the vibration kicked in. I have been listening with a stethescope for sounds, and it seems to have nothing strange. There are some ticks from a couple valves that are to loose. I am just hoping that it isn't something that i have to tear it down to find. I like to know what it might be before i tear into something. At this point, i have no clue.1980 XS1100LG Midnight
A cold beer and another one!Comment
+1 on the engine mounts. Look at the ones at the front of the engine near the cam chain tensioner.'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
'84 Chevy K-10 "Big Blue"
"What they do have is an implacable, unrelenting presence and movement that bespeaks massive power lurking behind paint and chrome. They don't wail like a screeching ninja, the don't rumble like a harley. They just growl like a spactic, stressed out badger waiting to rip your face off and eat your soul." Trainzz~RIP~Comment
Are you sure you have gas on both sides of the tank? I ran out on one side and it started vibrating/shaking like something was really wrong. More than once I have helped someone (and me) troubleshoot a car that would not start only to find out .......no gas. I'm not trying to insult you, sometimes it is a very simple solution, so simple we tend to overlook it."Galaxy" 1982 XJ1100J, 1983 XV handlebars, new fusebox, homemade SS wind screen and SS muffler heat shields, homemade grab bar extension and luggage rack. XS750 140 mph speedo, '81 Venture oil cooler, V-Max ACCT, Yahman YICS Eliminator, 1st and 2nd gear Dremel fix.Comment
Is there a descent way to check those mounts. With the pry bar, i get movement out of the mounts on both sides. What is the acceptable movement? Thought maybe it was the rubber flexing. If it is just the mounts, i can ride it until i can fix it. It is my only transportation right now.Last edited by XS1100 Newbie; 04-23-2013, 06:12 AM.1980 XS1100LG Midnight
Just pulled my chain tensioner, and found nothing. Seems to be fine. Compared it to the old one i replaced, and they both were extended the same.1980 XS1100LG Midnight
look at the vibration dampeners
at the front upper motor mounts, if you have less than a 1/16 th inch or worse, metel touching metal, that's where the vibration is coming from.mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Comment
Checked the exhaust bolts all the way back. All tight. Banged on it and didn't get any rattles. Checked my middle drive, and found it low on fluid, but not to much. Removed windscreen, as it was vibrating. Check final drive, good. checked front upper mounts, and they appear to be ok. I am going to brave it, and ride it 20 miles to our bike night to see if all this made any difference. Hopefully it doesn't put me on the pavement.1980 XS1100LG Midnight
A while back, I encountered a strange vibration under acceleration only. Thinking it was a bad U-joint, I replaced it and no change, it turned out to be the three bolts at the rear of the middle drive unit under the rubber boot were loose. Tightened them up and the vibration was gone. Probably not your issue if you say it vibrates while revving in neutral.2H7 (79) owned since '89
☮Comment
I will still check them. Thanks.1980 XS1100LG Midnight
