Bad vibrations
  • XS1100 Newbie
    • Jun 2009
    • 1106
    • Battle Ground, Washington
    Bad vibrations
    Today when coming home the bike was vibrating. Don't know how to explain it, but i will try. When applying throttle, the vibration was a harder vibration. At idle, or at higher rpm's it is more of a milder, although faster vibration. If i pulled the clutch in and coasted, the vibrations were gone. That told me it was probably not the rotation of a tire, but in the engine. When i got home, i started it, and took the rpm's up. There was a lot of noise coming from the front, or top of the engine. The question would be, can a cam chain cause this? I suppose it could. I jus put the auto tensioner on about last Novenber. That is about 3200 miles. Any ideas on what or how to check for this damn thing?
    1980 XS1100LG Midnight
    1991 Honda CBR1000F Hurricane
    A cold beer and another one!
  • Gallaecus
    • May 2011
    • 254
    • East Haven Connecticut
    might want to check your engine mounts and the vibration dampers.
    Steven
    1981 XS 1100 LH
    1979 XS 1100 SF
    • Yahman
      • Mar 2008
      • 779
      • Salem, OR
      Did you run it through the RPM's when you were coasting?
      Ride safe,
      Larry
      82 XJ1100
      80 XS1100G (Project bike)
      64 Yamaha YA-6
      77 Suzuki TS-185
      • XS1100 Newbie
        • Jun 2009
        • 1106
        I did Larry. Whenever i brought the rpm's up the vibration kicked in. I have been listening with a stethescope for sounds, and it seems to have nothing strange. There are some ticks from a couple valves that are to loose. I am just hoping that it isn't something that i have to tear it down to find. I like to know what it might be before i tear into something. At this point, i have no clue.
        • WMarshy
          • Apr 2009
          • 2402
          • Mexico NY
          +1 on the engine mounts. Look at the ones at the front of the engine near the cam chain tensioner.
          '79 XS11 F
          Stock except K&N
          '79 XS11 SF
          Stock, no title.
          '84 Chevy K-10 "Big Blue"
          • XJkid
            • Jun 2003
            • 280
            • Elk Grove, Ca.
            Are you sure you have gas on both sides of the tank? I ran out on one side and it started vibrating/shaking like something was really wrong. More than once I have helped someone (and me) troubleshoot a car that would not start only to find out .......no gas. I'm not trying to insult you, sometimes it is a very simple solution, so simple we tend to overlook it.
            • XS1100 Newbie
              • Jun 2009
              • 1106
              Is there a descent way to check those mounts. With the pry bar, i get movement out of the mounts on both sides. What is the acceptable movement? Thought maybe it was the rubber flexing. If it is just the mounts, i can ride it until i can fix it. It is my only transportation right now.
              • XS1100 Newbie
                • Jun 2009
                • 1106
                Just pulled my chain tensioner, and found nothing. Seems to be fine. Compared it to the old one i replaced, and they both were extended the same.
                • mack
                  • 2411
                  • Ontario, Canada
                  look at the vibration dampeners
                  at the front upper motor mounts, if you have less than a 1/16 th inch or worse, metel touching metal, that's where the vibration is coming from.
                  mack
                  79 XS 1100 SF Special
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  https://youtu.be/wB5Jfbp6SUc
                  https://youtu.be/RaI3WYHSuWA
                  Frankford, Ont, Canada
                  613-398-6186
                    • 8863
                    You can check your exhaust mounting points, loose bolts may cause a vibration, JAT
                    • XS1100 Newbie
                      • Jun 2009
                      • 1106
                      Checked the exhaust bolts all the way back. All tight. Banged on it and didn't get any rattles. Checked my middle drive, and found it low on fluid, but not to much. Removed windscreen, as it was vibrating. Check final drive, good. checked front upper mounts, and they appear to be ok. I am going to brave it, and ride it 20 miles to our bike night to see if all this made any difference. Hopefully it doesn't put me on the pavement.
                        • 8863
                        A while back, I encountered a strange vibration under acceleration only. Thinking it was a bad U-joint, I replaced it and no change, it turned out to be the three bolts at the rear of the middle drive unit under the rubber boot were loose. Tightened them up and the vibration was gone. Probably not your issue if you say it vibrates while revving in neutral.
                        • XS1100 Newbie
                          • Jun 2009
                          • 1106
                          I will still check them. Thanks.
