Caliper wont fit
  • Tat2demon
    • Jun 2012
    • 718
    • Sioux Falls, South Dakota
    Caliper wont fit
    I tried to put my front brake calipers back on tonight after putting in fork seals and I cant seem to get the left side caliper to go back on. Once the pads are over the rotor, there is still about 1/4 inch to go before I can get the mounts on the inside of the fork.
    I looked in the book and didn't see anything but is there supposed to be a washer between the speedo sensor and the fork? That's the only thing I can think of that would cause this.
    Nate
    78 XS11 "Matilda" 2H7 000364
    K+N Air Filter
    88 Voyager XII
    81 XJ650 Maxim
  • Nightengale
    • Jun 2011
    • 521
    • Hampton, VA.
    washer
    I just had my front tire off to change the tire and i dont remember a washer at the speedo gear.
    xs1100 hartail bobber
    http://i1169.photobucket.com/albums/...-38-36_563.jpg
      I am not certain on the Standards as I have not worked on one as of yet. However, the Special I know has no spacer / washer. The parts fishe for the Standard shows no spacer.
      Is the caliper itself hitting the fork? Or is the brake pad not fitting?
      Of course you can try pushing the caliper piston all the way if it is not now, and see if that helps. JAT
      • mikubuilder
        • Jul 2011
        • 548
        • Westland, Mich.
        you have to make sure that the pinch bolts are loose, and only axle nut tight....then set your left fork tube to center rotor in caliper, and then tighten pinch bolts...
        Nick
        1982 Virago 750 (it's alive!)
        • mikubuilder
          • Jul 2011
          • 548
          • Westland, Mich.
          also make sure that speedo sits in it's notches
          Nick
            • 3372
            Ditto that...
            My bet is the speedo drive isn't seated/lined up like it should be.
            2001 ZRX 1200
            1982 Seca 750
            1983 Nighthawk 550
            • Tat2demon
              • Jun 2012
              • 718
              The speedo was fine but Miku was right. I had tightened the collar first, then the castle nut.
              Nate
              K+N Air Filter
              88 Voyager XII
              81 XJ650 Maxim
                • 3372
                Glad you got it 'figgered out!
                2001 ZRX 1200
                1982 Seca 750
                1983 Nighthawk 550
