I found a set of carbs from a Special. I'd like to get them for my Standard. Will they bolt up? Minimal difficulty in the swap? I've read they should have less tee vents since the vents on Special are run through carb inlet housing, is that correct? Thanks for the help!
Special Carbs on a Standard?
AFAIK any year or model XS11 carb rack will fit on any XS11.
Be sure to plumb and jet them up according to the carb rack's year and model, NOT the bike's.Fred Hill, S'toon
"The Flying Pumpkin" -
The 1978 and 1979 model carbs used an external vent from the fuel bowl. There are separate Ts that operate as vents for the bowls. They are directly above the fuel inlet Ts. The 80-81 and XJ model carbs have an internal vent for the fuel bowl. If you look at the inlet bell, the 78-79 model has three holes in the inlet bell, the 80-81s have four holes, the added one is the bowl vent.Life is what happens while your planning everything else!
78 XS750Comment
