Gauge disassembly
  • Tat2demon
    • Jun 2012
    • 718
    • Sioux Falls, South Dakota
    Gauge disassembly
    Is it possible to take apart the tach to clean the inside? Mine is all fogged up on the top half.
    Nate
    78 XS11 "Matilda" 2H7 000364
    K+N Air Filter
    88 Voyager XII
    81 XJ650 Maxim
  • WMarshy
    • Apr 2009
    • 2402
    • Mexico NY
    I believe a few people have done it. Use the search tool some and you might find some threads about it and general warnings while you wait for someone with fist hand experience...
    '79 XS11 F
    Stock except K&N
    '79 XS11 SF
    Stock, no title.
    '84 Chevy K-10 "Big Blue"
      The XS gauges are sealed units and not designed to be disassembled. It can be done, but usually will leave you with a somewhat damaged looking trim ring on the gauge as it's extremely difficult to get it off and re-crimped on without denting the ring. Do a search, there's multiple threads about this.
      If appearance is important, you'll be better off just getting another gauge IMO...
        If money is not a problem, there are also companies that will take old gauges and refurb and clean then. It is usually a couple hundred per gauge though...
        • Eveready1100
          • 539
          If it's just fogging up, take the guage off the bike, take the outer housing off. With the rubber plugs that hold the guage lights removed from the gauge, put it on a tray face down and heat it up with a hairdryer. Nearly all of the moisure that was trapped in there will evaporate away.
            I have not yet tried a tach (but may need to on the SG), but I have opened the speedo before. You can use a small screw driver to carefully pry the trim ring back to open it. The under edge of the trim ring looked like holy terror by the time I was done, but it went back together, and the rubber seal hides that under side, so you would never know to look at ti in place.
              Joel Levine Company web site
              All British, European, American and Japanese gauges can be remanufactured to as new with a one year warranty.
              If needed any gauge can be supplied with a new dial face, chrome bezel-ring, number drums ect. So it meets the costumer’s requirements
              - repair time is typically 7-10 days
              - please call or email for pricing
              Please call or contact us for more information.
              Joel Levine Co.
              1226 B Zonolite Place
              Atlanta, GA 30306
              USA
              Phone: 404-219-0594
              Fax: 404-249-9911
              Toll Free: 800-456-6267
                Hi Nate,
                like they all say, yes you can but it's a bitch to do.
                What's it fogged with?
                If you or the dreaded PO was fizzing in there with spray lube a teardown is the only way.
                If it's moisture, low tech is a hair drier or a ride in the oven at a tad under boiling point.
                High tech is a ride in a vacuum chamber.
                • Tat2demon
                  • Jun 2012
                  • 718
                  Im not sure what it is. Looks a lot like the inside of a smokers car window that hasnt cleaned it in a couple years. Definitely not moisture. Looking like my best bet is to wait and find a replacement.
                  Nate
                  K+N Air Filter
                  88 Voyager XII
                  81 XJ650 Maxim
                  • jwhughes3
                    • 2798
                    • Home of the Alamo
                    QD Electronic Cleaner evaporates without residue. Might be worth shooting inside to see if it cleans it.
                    John
                    '81 XS1100H - "Enterprise"
                      • 3193
                      You may want to look at this page and the links in it.
                      • Tat2demon
                        • Jun 2012
                        • 718
                        Thanks, saw that this morning. Trying to find a nippers small enough for the job around here is proving to be a little difficult.
                        Nate
                        K+N Air Filter
                        88 Voyager XII
                        81 XJ650 Maxim
                          • 3193
                          I found the fix (link) at the bottom thread to be an interesting and good looking fix.
                          • Tat2demon
                            • Jun 2012
                            • 718
                            Think that would work very well on the square gauge?
                            Nate
                            K+N Air Filter
                            88 Voyager XII
                            81 XJ650 Maxim
                              • 3193
                              The nippers pulled it off just fine for me on a square gauge too. Just a bit more care needed on the corners. As for the fix I am not sure but I imagine it would be ok.
