Middle Drive Filler Plug
  • unicorncomputer
    • Jun 2012
    • 140
    • Southern Vermont
    When I went to change the Middle drive oil, I noticed the filler plug allen hole has been stripped by the previous owner. I will slot it with a dremel to get it out, but I would like to know what size bolt it is so I can get one ahead of time.
    Thank you,
    Steve
    79 XS1100 SF
    Both the middle and final drive drain and fill plugs are the same thread, as well as the pol drain plug. All can be interchanged as the threads are the same.
    Although the final drive fill plug needs to be a little shorter than the others.
    When you get a new fill plug for the middle get one for the final as well, same crappy Allen hole.
    • xs650man
      • Feb 2013
      • 90
      • Christchurch, New Zealand
      Its 14 X 2 mm. I had the same problem with my final drive bung, I ended up welding a nut to it, ( the heat helps loosen it ) presto. My middle drive bung was in good condition but I still couldn't get it undone even with a pipe on the allen key, so I took the bike for a short ride to warm everything up ( thanks Brian W ) then tried again, got it.
      80 SG
      93 ST1100 Honda
      66 split screen VW bus
      • unicorncomputer
        • Jun 2012
        • 140
        • Southern Vermont
        great, thank you both.
        79 XS1100 SF
        • DAVINCI
          • Jan 2011
          • 1048
          • Cedar Mountain, NC
          Go one better, replace them both (mid and final) with a magnetic hex head drain plug, no more allen!:
          A standard Suzuki part, BikeMaster number FHM050-S14-12.5
          • DAVINCI
            • Jan 2011
            • 1048
            Amazon.com sells 'em:
            http://www.amazon.com/BikeMaster-Ste.../dp/B003177B4C
            • donebysunday
              • Oct 2012
              • 1737
              • New Berlin, Wi.
              Originally posted by DAVINCI
              Thank You ! $18.90 free shipping for 2
              76 XS650 C ROADSTER
              80 XS650 G Special II
              https://ibb.co/album/icbGgF
              80 XS 1100 SG
              81 XS 1100LH/SH DARKHORSE
              https://tinyurl.com/k6nzvtw
              AKA; Don'e, UD, Unca Don'e
                You can get the magnetic drain plugs at the auto parts store for $2-4.
                • DAVINCI
                  • Jan 2011
                  • 1048
                  Yes, true, Nate but it's hard to find the ones with the narrow shoulder on them to fit the final drive. At least, that's what I've found. Some of the guys have ground them down to fit, but that's not my preference.
                    That is true. This is only a problem for the final drive whith the recessedseating surface. I just held my cheap bolt lightly in my fingers and let it roll as I held it to the bench grinder. Took it down just right and fits perfect.
                    • xs650man
                      • Feb 2013
                      • 90
                      Correction , its 14 x 1.5 not 14 x 2 as I stated earlier, that one from Amazon is 14 x 1.25 so be careful,
                      80 SG
                      93 ST1100 Honda
                        • 5069
                        There is no problem at all with the stock ones if you use a nylon washer.
