Hey everyone. Will try to keep short, but must explain situation. Have '80G with fairing and bags. All lights were working perfectly. Man pulled fron garage, low speed impact with T/Pole. Ruined front fairing, bent handlebar on left side at light switch area and wiring harness area near switch. Found and purchased Yamaha Pacifico factory fairing.
Ok, problems I have. 1. Installed fairing, headlight and aftermarket installed led lights (mounted on lower L & R corners of fairing above lowers mounting holes) inop even with bike running.(H/light was inop immed. after accident,figured broken bulb.) Replaced w/new bulb, no headlights. Running lights work fine. 2. All t/signals work, but front signals flash opposite of switch, turn L/side on and Right signal flashes and vice versa. Rears flash correctly. 3. When put brake on, signals stop flashing and go solid. 4. When warming bike up with choke or revving RPM's, small puffs of smoke at front of intake boots where it meets the engine.
Sorry so long, any help greatly appreciated. ( I do have nice colored wiring diagram, but all looks greek to me. I do have electronic multi tester if that helps me.) Thank You everyone for any help.
P.S. Have NOT replaced bars
