Valve shim measurements
  • Tat2demon
    • Jun 2012
    • 718
    • Sioux Falls, South Dakota
    I just checked the clearances on my valves tonight for the first time. Im using go/no-go gauges.
    Here are the exhaust valve clearances from left to right - .152, .152, .127, .127
    Obviously these are way off of the recommended spec.
    Now the big problem. I cant fit my smallest gauge (.102/.152) under ANY of the intake shims.
    So my question is, with all of the valves being so far out of whack and the intakes being un-measurable, what should my next step be? Tomorrow Ill pull the cams and get numbers off the shims but with all of them being so far off, should I be looking for other problems?
    Nate
    78 XS11 "Matilda" 2H7 000364
    K+N Air Filter
    88 Voyager XII
    81 XJ650 Maxim
    If the bike has fairly even compression and/or was running well, the intakes are probably between .002" and .004". Generally, if the valves get tighter than .002", you'll get a miss or loss of compression. So figure on reducing shim size by two sizes and that will get you very close.
    I've seen them too tight to measure, an adjustment will fix it....
    • Tat2demon
      • Jun 2012
      • 718
      Yeah the bike runs fantastic. Hopefully a shop here in town will be willing to do some swapping with me. Would like to avoid buying shims for all 8 valves.
      Nate
      K+N Air Filter
      88 Voyager XII
      81 XJ650 Maxim
      • Tat2demon
        • Jun 2012
        • 718
        Ok so I just pulled all the shims.
        From left to right with the original gaps-
        .152 .152 .127 .127
        300 295 290 300
        NA NA NA NA
        270 265 275 275
        So...If Im looking at this correctly, what I need is-
        295 290 280 290
        260 255 265 265
        Anyone mind going over the chart and double checking my numbers?
        Nate
        K+N Air Filter
        88 Voyager XII
        81 XJ650 Maxim
          Converting those to inches...
          Exhaust
          .006 .006 .005 .005
          I'd drop all of them two sizes; you're better off to hit the upper end of the clearance as that way you'll have longer between adjustments. Each shim change difference is .002", so two sizes will increase them by .004".
          That should give you...
          EX: .010 .010 .009 .009
          IN: .006 .006 .006 .006 (or maybe a bit more; remember, the early intake spec can be as much as .008". A bit more noise, but more time between... )
          • GLoweVA
            • Jun 2011
            • 1957
            • Virginia Beach, VA.
            As far as checking locally, check your BMW bike dealer too. Those Beamers also use the same size shims and they may be willing to trade/sell you shims.
            80G (Green paint(PO idea))
            The Green Monster
            Got him in '04.
            bald tire & borrowing parts
            Scarlet
            Got her in '11
            Ready for the twisties!
            81H (previously CPMaynard's)
            Hugo
            Cold weather ride
            • Tat2demon
              • Jun 2012
              • 718
              The second place I called had a large box of them. Swapped them out for $3 each.
              Nate
              K+N Air Filter
              88 Voyager XII
              81 XJ650 Maxim
              • Tat2demon
                • Jun 2012
                • 718
                Got em all put in and everything bolted back together. Retested and two of them are still off by one size. One intake and one exhaust. Steve, your guess of two sizes was right on. Im going to wait until my Motion Pro shows up in a day or two. Im not going to pull the cams for just two shims.
                Thanks for all the help guys. Now that Ive done it, not that difficult of a job.
                Nate
                K+N Air Filter
                88 Voyager XII
                81 XJ650 Maxim
