I think I win the contest of spoog in the brake system.
  • sparkfly88
    • Mar 2013
    • 585
    • CedarKey FL
    My front brakes are hanging up I think, the front tire doesn't easily spin like the rear does.
    So, I totally took apart the system.... This is an example of what I found...
    This was under the master...
    This sludge was in both calipers..
    I cleaned the whole system, flushed and bled... But I think it's still hanging up.
    I can't remove the master to give it a better cleaning, it's corroded to the handlebar... So I think I'm gonna just cut it off and replace it with a 16mm mike's Xs master.
    79F
    "Excelsior"
    Honda gl1100 handlebar
    Vetter IV fairing with speaker system
    OE headers,Jardine slipons
    Hid headlight 6000k
    Stock jets
    Shinko 712 F & R
    Oe hardbags and luggage rack
    TC fuse block
    K&n filter with oe airbox
    Raptor 660 Acct
    • 3190
    I think mine is a wee bit worse than yours.
    Check out http://www.xs11.com/forum/showthread.php?t=24288 and then you will see what I mean.
    • sparkfly88
      • Mar 2013
      • 585
      • CedarKey FL
      I bow to you. Loooooool
      Good god man, that's just extreme.
      79F
      "Excelsior"
      Hid headlight 6000k
      Stock jets
      Shinko 712 F & R
      TC fuse block
      Raptor 660 Acct
        Originally posted by sparkfly88
        [IMG]
        http://img.photobucket.com/albums/v211/Sparkfly88/20130408_185511.jpg[/IMG]
        That won't even get you into the top ten.....
          Hate to say it, but that looks like new fluid compared to what I have pulled out myself and seen in other bikes on here.
          But it is sad how bad it got without being given some love.
          • donebysunday
            • Oct 2012
            • 1737
            • New Berlin, Wi.
            [QUOTE=sparkfly88;405840]My front brakes are hanging up I think, the front tire doesn't easily spin like the rear does.
            Worst I've ever seen out of 57 in the last 15 years ?
            76 XS650 C ROADSTER
            80 XS650 G Special II
            https://ibb.co/album/icbGgF
            80 XS 1100 SG
            81 XS 1100LH/SH DARKHORSE
            https://tinyurl.com/k6nzvtw
            AKA; Don'e, UD, Unca Don'e
            • dpotter58
              • Aug 2004
              • 1852
              • Southern Maryland
              you probably have the same crap in the lines. Better off to replace them as weel if you can afford it or you will chase the problem forever.
              1980 LG
              1981 LH
              • sparkfly88
                • Mar 2013
                • 585
                • CedarKey FL
                So Thursday when I get paid...master, lines, caliper kits....
                Woo
                79F
                "Excelsior"
                Hid headlight 6000k
                Stock jets
                Shinko 712 F & R
                TC fuse block
                Raptor 660 Acct
                  If you have the money it is not a bad idea to put new kits in the MC and the calipers. However, very often, if you clean up the parts you have, they will work just fine for years to come. Never know till you get in and see the condition of the rubber components. Even bigger issue is if the pistons are corroded in the calipers. You might want to check that out first.
                  • sparkfly88
                    • Mar 2013
                    • 585
                    • CedarKey FL
                    Caliper Pistons are fine somehow...
                    79F
                    "Excelsior"
                    Hid headlight 6000k
                    Stock jets
                    Shinko 712 F & R
                    TC fuse block
                    Raptor 660 Acct
                    • clcorbin
                      • Jan 2010
                      • 495
                      • Albuquerque, NM
                      I'm happy to say this is one contest I am HAPPY to lose! When I went through the brake system on my 79F last year, I was very surprised how good everything looked. Very little rust and almost no spoog in the system. Of course, the bike has lived it's whole life in the desert, so that probably has a LOT to do with it!
                      -- Clint
                      • sparkfly88
                        • Mar 2013
                        • 585
                        • CedarKey FL
                        I just did the rear brake yesterday.... It locked up totally. Lol...
                        The caliper had so much goop behind it.... Oh man... Took everything apart and cleaned it up.
                        Works like new. Lol.
                        79F
                        "Excelsior"
                        Hid headlight 6000k
                        Stock jets
                        Shinko 712 F & R
                        TC fuse block
                        Raptor 660 Acct
