valve adjustment
  • old_skool
    • Nov 2011
    • 554
    • Ohio
    valve adjustment
    Having issues with the search feature, may be me, but anyway, never adjusted valves on an xs1100, got an 81 I'll be tearing down to the frame for a paint the frame up resto, want to adjust the valves while I have the engine out when I get to that point, is there a tutorial in the tech section somewhere? If someone can post a link it would be appreciated, I've done many GS1100's, is it the same procedure, or something else?
    Thanks Rich
    oh yeah, and a link for the washer move for second gear if it's not too much trouble, having computer isses, sorry.
    81 XS1100H
    Search on valve adjustment on youtube and you should find a couple descriptions. I think the reason there has never been a detailed published tech tip is that if you mention valve adjustment, you get lots of discussion on how to do it. The two main methods involve either using the tool, or loosening/removing the cams. Done it both ways myself. I have my preference, but either one works.
    • old_skool
      • Nov 2011
      • 554
      • Ohio
      is it a basic remove valve cover, align cams to right position, remove, measure, replace shim on cam bucket type of adjustment, or is there more to it on these, like i said, I've done plenty on Suzuki's, just never had the valve cover off of a yamahammer yet, maybe I'll do a right up with pics.
      And as far as searching, keys on my keyboard are working only when they want too, need a new one.
      81 XS1100H
        • old_skool
          • Nov 2011
          • 554
          • Ohio
          Thanks, actually found that one, just before you posted.
          81 XS1100H
