Self-cancelling Flasher System
  • Phyxius
    • 47
    • Otsego, MI
    Does anyone know the part number for the flasher cancelling unit on a '79 Special and/or where to purchase this part?
    If it doesn't have an engine, it's not a sport, it's only a game. (borrowed from strom)
    The idea is to die young............as late as possible.
    1979 XS1100SF Special
  • steelcat
    • Feb 2004
    • 68
    • Elko, NV
    The p/n for the flasher relay assy. is 2F0-83350-70-00.
    The p/n for the flasher cancel assy. is 1A0-83395-03-00.
    Ken
    '79 xs1100f
    '79 xs1100sf
      Re: Self-cancelling Flasher System
      Does the signal just stay on? If so, you might try cleaning out the turn signal switch on the handlebar. It is a "momentary contact" switch and if it gets gummed-out in there, it makes continuous contact. New parts cost a fortune.
        To turn off the signal light, it should return to center on it's own, and all you have to do is press in on the switch button. That's how mine works.
        • rover
          • Jan 2004
          • 765
          • central WI (715)
          John is right about how to turn off the signals manually. If your flasher is burned out, the replacement is very expensive, over $40.00. A two prong heavy duty automotive flasher works just fine. Just remove the old one, and put the two prong one in, andn if your flashers don't work, use the other prong, as one of the three is for the self-cancelling function. In other words, there are three prongs on the original, and two on the automotive one. You just don't use one of them. Rover
          79 F (Blueballs)
          79 SF (Redbutt)
          81 LH (organ donor)
          76 CB 750 (gone to MC heaven)
          rover has spoken
          • newmaac
            • Dec 2002
            • 369
            • San Jose, CA
            After cleaning the connections and the inside of the switch on yours, if it still doesn't work, I am pretty certain that I have a few good used ones.
            Let me know if you still need one.
            Mike
            1980 SG "Angus"
            • Phyxius
              • 47
              • Otsego, MI
              I'll check the turn signal switch and see if it needs cleaned, as well as the cancellation unit itself. When I use the signals, they do continue flashing, and pushing the switch button down turns it off manually. It's just a little quirk of mine: if something is supposed to be there and isn't, I replace it, and if it's not working, I fix it, if at all possible.
              I'll reply back to this thread, newmaac, after I see if cleaning helps. I might get with you anyway, never hurts to have a few spare parts around just in case.
              • Phyxius
                • 47
                • Otsego, MI
                Just looked up the part numbers on BikeBandit.com (thanks Steelcat), and you're right Rover:
                flasher relay: $68.62 + shipping
                flasher cancel unit: $74.19 + shipping
                Here's hoping a good contact cleaning is all I need.........
                • randy
                  • Dec 2003
                  • 4521
                  For the turn signals, in addition to the cancelling unit there is a sending unit that is part of the speedometer. This unit ticks off 1/4 to 1/2 mile IIRC, then electrically trips the cancelling unit. there is a post on this site that describes using WD-40 to clean out the works. Do a search. Check out the wiring from the Speedo first, clean all of the comnnections and see what you get.
                  Hope this helps.
                  Randy
