new valve stem seals
  • XS1100 Newbie
    • Jun 2009
    • 1106
    • Battle Ground, Washington
    Is there better stem seals than OEM, or should i just stay with Yamaha? I figure that there must be good quality seals out there, but maybe it is just wishful thinking.
    1980 XS1100LG Midnight
    1991 Honda CBR1000F Hurricane
    A cold beer and another one!
    • 7765
    If you get a complete engine overhaul gasket set, it should have seals included. That's all I've used, and had no problems so far. But then, most of the bikes I now have have NOT had any work done, and still have no problems with seals after 30+ years.
      Are you talking valve stems on the wheel or valve seals in the engine?
      • XS1100 Newbie
        • Jun 2009
        • 1106
        Engine valve stem seals Nate.
        • XS1100_OEM4ME
          • Mar 2009
          • 1619
          • Fort Myers, Florida
          Install
          I have found that carful instalation is the most important thing, dont damage them and center them and you should be fine. +, if your valve guilds are worn, have them repaired 1st, if the guilds are lose the seals will fail alot faster. Good luck with your bike
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
