Well, that figures
  • LoHo
    • Sep 2002
    • 1342
    • Fresno, CA
    Well, that figures
    I have been trying to figure out a high RPM problem, among others. I keep thinking I have the Beast zeroed in, get her started, then she revs at 2k and attempts at getting that down or synching are for naught.
    As I tried different things to even her out and get her RPMs down, only to have her rev back up and be out of sych. I use the four-dial vacuum hose attachments to synch. I noticed that one of them went to zero when I turned the small air screw on the hose to control the needle vibration. It should just get stuck at whatever the vacuum level is, not go to zero. Closer inspection:
    The screw was cracked on the engine side, so that I introduced a vacuum leak, hence the high revs. Also, can you guess which carb it was on, screwing up any other settings? Number 3? You are a winner.
    The things I've done to this bike over a 27 cent part....
  • LoHo
    • Sep 2002
    • 1342
    • Fresno, CA
    In truth, it was $2.37 at the local expensive pet store.
      Its always the simple things that cost us the most time and effort!
      • LoHo
        • Sep 2002
        • 1342
        • Fresno, CA
        Replaced that part and in two minutes I had gotten the RPMs down to about 700 (then set to 1100) and all four jugs pull the same vacuum. Amazing.
        Now the often-abused valve cover gasket leaks a ton, but I can do that. Can the road be far ahead? Probably.
        What's next? Exhaust mites? Gear-anoma? Pulling a Diver Ray on the rear drive?
        • mack
          • 2411
          • Ontario, Canada
          Can
          you imagine what you would have spent for a shop to run that problem down for you?
          mack
          79 XS 1100 SF Special
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          https://youtu.be/wB5Jfbp6SUc
          https://youtu.be/RaI3WYHSuWA
          Frankford, Ont, Canada
          613-398-6186
            • 2096
            Careful what you wish for
            Aint that a beautiful sound when they're all in sync ?
            Kudos to ya
              • 7817
              Hey, that was a TRANSMISSION, NOT a final drive that locked up!! Glad you got the problem fixed! maybe you will think about Half Moon Bay the end of April. Ed and I could use another XS to keep the HD crowd at bay. Rooms are not too much, and they do have camping nearby If you want to go that route.
              • LoHo
                • Sep 2002
                • 1342
                • Fresno, CA
                I thought that might rattle your cage.
                I am considering Half Moon Bay, which is a great place to go in any event.
                  • 7817
                  I just got a room with two beds for $162. Saturday night, two miles from the airport. Comfort Inn, Half Moon Bay with my choice number. The web site for the event lists a place with RV and camping, but I do NOT know what the price is.
                  Hope to see you, and ride together again!
                  • LoHo
                    • Sep 2002
                    • 1342
                    • Fresno, CA
                    The saga took a new turn today. The new valve cover gasket showed up, was installed, and for the first time since November of 2010, F*****g B***h went under her own power to gas up and go for a spin around the neighborhood. Now to change non-op to registration, and off we'll go.
                    Thanks for the help, gentlemen. Most of my drama was self-imposed, but between grasping at straws and following up leads from y'all, I learned a lot, and am back in business.
                      AWESOME!!!! I am very pleased to hear you got the B!T$% running!! I could feel your frustration, so it is good to know you got the pleasure of finally having a running bike again. Excellent dedication to the beast, and great work!!
                      • LoHo
                        • Sep 2002
                        • 1342
                        • Fresno, CA
                        Has anyone noticed a rhyme or reason for valve cover gasket thickness?The one I used for years was about an eighth thick and sealed well. The last one I bought was about as thin as a manilla envelope and delicate and seeped constantly. The one I just got was in between, but thick enough to compress and fill the gap.
                          I have used RTV for valve covers since about 1980.
                          • rpgoerlich
                            • Dec 2007
                            • 643
                            • Katy, Tx
                            Years ago I bought 4 from a guy in NZ for $8(US)ea. Took a month on the slow boat but they were the thin ones as well.
                            I quit using them a few valve adjustment ago. Started using The Right Stuff. Never have had a leak yet.
                            Richard
