So in preperation for firing up my 80SG I pulled the valve cover off to prelube the camlobes with some clevite77 assembly lube. I wrenched it over by hand for a few revolutions and noted that all the lobes wiped nicely between the themselves and their shim EXCEPT one intake on no.3 cylinder. It seems to have a big enough gap that I can actually pull the shim out with a magnet. NO way that is right. The lobe pushes it down into the bore, but it's like the thing isn't coming all the way back up??? Bear in mind this bike sat for 3 yrs without being run. My next thought is to pull the plugs, put in the battery and crank it over to see if the spring/bucket/shim come all the way up with a bit of action? Would REALLy appreciate some input on this one, as I don't want to F up the engine!! It is def. not rising that last 1/16".
Well for some reason, that cylinder although sealed just like the others has some rust on the valve stem and probably seat, that is what is keeping the valve from rising up completely. Take a look at a good one, and then the problem one. So, any suggestions???? How long does it take to pull a head? The exhaust and carbs are already off.
