Standard/80G front turn signals
    • 3352
    I believe there is unobtanium status of turn signal mounts for Standard's.
    My 80G came with a beater Pacifico fairing, and I would like to convert it back to stock, if you will.
    Couple of things...
    -Can a round Special headlight bucket fit the Standard mounting ears? Or is the Standard bucket the only fit?
    -What turn signals have been substituted due to the hard to find nature of Standard mounts?
    Thanks in advance.
    2001 ZRX 1200
    1982 Seca 750
    1983 Nighthawk 550
    You could mount special turn signals in a standard bucket (mounted like they would be on the special).
      • 3352
      Thanks for the input!
      2001 ZRX 1200
      1982 Seca 750
      1983 Nighthawk 550
      • GLoweVA
        • Jun 2011
        • 1957
        • Virginia Beach, VA.
        Howard, here's a pic to show you what it'd look like:
        That's my SG's lights on my G. My fairing broke badly and I needed a headlight and signals PDQ, so I pull them off my nonrunning SG.
        The adjustment arm on the bottom was a bit of a PITA, so the light aimed a little high.
        If you noticed, that's not a stock SG light. At the time, TC was borrowing my standard bulb for his HID comparison test, but the housing is stock.
        80G (Green paint(PO idea))
        The Green Monster
        Got him in '04.
        bald tire & borrowing parts
        Scarlet
        Got her in '11
        Ready for the twisties!
        81H (previously CPMaynard's)
        Hugo
        Cold weather ride
          • 3352
          So in simple terms it looks like a Special headlight housing and headlight along with turn signals will graft right on to the mounting ears, yes?
          2001 ZRX 1200
          1982 Seca 750
          1983 Nighthawk 550
          • GLoweVA
            • Jun 2011
            • 1957
            If you headlight ears are snug, (they don't flop around left to right)
            and your G will have an extra wire that would have run to the running light, (the SG signals only have one filament for the turn light)
            and you'll have to play with the adjustment linkage to make it aim right.
            Yes, simple answer it'll fit. (might not look super pretty)
            The Green Monster
            Got him in '04.
            Scarlet
            Got her in '11
            Hugo
            Cold weather ride
              Hey Bonser,
              The Standard signal mounts are just POSTS on a bracket that bolts to the front edge of the lower triple tree fork clamp bolts. You can see them on the parts Fiche site! I would think you could fab up something similar to bolt there, then you could mount the aftermarket signals from Partsnmore.com onto them. PNM shows both a rectangle 1 wire and 2 wire signal....but the colors are red/black for the 2 wire, but it doesn't say it's a dual filiment running and turn signal socket??? But it's the right shape!?
              Turn Signal Lamp
              #11-2187 | Yamaha XS1100 (1978-1981)
              Turn Signal Lamp 2- Wire - Front or Rear
              US$ 17.95
              Fits: XS1100 (78-81)
              When I relocated my rear signals due to my saddlebags, I just welded some pipe onto the bag brackets, and was able to clamp the XJ signal housings onto them.
