fuel line size
  • 650mark
    • Jul 2012
    • 307
    • Mesa, Az.
    fuel line size
    19880 xs1100 special, all stock and original with octy. what size are the fuel hoses? 1/4" or 5/16" inside diameter? are they all the same i.d? thanks
    You want the 1/4" I.D.
    • 650mark
      • Jul 2012
      • 307
      • Mesa, Az.
      thanks phil
        Yep, be aware that some types of line have a larger O.D than the stock line which means those factory spring clamps may or may not work.
        • mlew
          • Jun 2005
          • 226
          • Apex , NC
          1/4 will work, check at auto parts stores for metric sizes. I found a roll of 6mm fuel line at one near me. It was a perfect replacement for the original. I have used regular 1/4 fuel line but it is so bulky to fit around the carbs and valves I had to find something better.
          Slow down and enjoy life. If you are in that much of a hurry, you should have left eariler.
          Current rides:
          80 XS1100SG
          82 JX1100
          83 Venture Royale
          86 V-Max
          • Courtney
            • 542
            • Nanaimo BC Canada
            So 6mm or 1/4" I.D. is the correct size for all the fuel lines? There is only one size on the whole fuel system from tank to carbs?
            Bone stock 1980 Special except for the exhaust and crashbars. Oh yeah, and the scabbard for the Winchester Defender.
            • mlew
              • Jun 2005
              • 226
              • Apex , NC
              Yes either one will work, remember what Phil said. The regular 1/4 line at the auto parts store has a thick wall and the OEM spring calmps won't fit. It is also harder to fit all the lines in the tight spaces.
              I have seen some people use 1/4 Tygon tubing for fuel lines.
              Current rides:
              80 XS1100SG
              82 JX1100
              83 Venture Royale
              86 V-Max
