Hello I have an 82 xj1100 and the front wheel is bent and I need a replacement will the xj xs 550 and up front wheel work on the xj1100? Thanks
front wheel interchange?
Yes Jim its the same size.
JohnJohn is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
"Not all treasure is silver and gold" -
Is the hub the same though John?
Bearings, axle dia., hub width, rotor mounting, ect., ect...........
According to the parts fiche the 550 and the 1100 front wheels ar different part numbers.Greg
Hi Jim,
if and only if (someone chime in here because I dunno) XS11 & XJ11 front wheels will interchange,
any XS series front wheel will fit, including a wire wheel from an XS650.Fred Hill, S'toon
"The Flying Pumpkin"Comment
Hi Jim,
all XS series front wheels interchange. I know for sure because I done it.
My own XS11SG has been rolling on an XS650 front since the last tire swap.
What I don't know is if XS fronts swap with XJ11 swirly fronts or if any or all of the XJ series fronts interchange.
Someone who has tried it will have to tell us.Fred Hill, S'toon
I do not know the answer to your question, however, I will tell you for certain that 90% of the ebay sellers have no clue and will assume they fit when they list it, but put a disclaimer in the ad for you to make sure it fits before you bid.Life is what happens while your planning everything else!
78 XS750Comment
An 81 midnight Special XS11 front wheel should be the same fit also as the 82 XJ11, the swirly type. If you don't care if they match, any XS11 wheel will fit. The picture at the top of the forum page shows the two different types.2H7 (79) owned since '89
☮Comment
Hey James,
A review of the AXLES for the XJ and XS11's are the same...it has been superceded with a newer #, but it shows the old # as well.
The XJ650's for example show a different newer number, and seems to be the same for the XJ smaller series bikes, so I'm thinking that they are a different SIZE...and probably would NOT fit. As has been stated, we know that the XS series bikes, at least the XS650's will fit, but they've been around a lot longer, so that's probably why they have/use the same axle as the XS11's, and XJ11, but the XJ 550's and 650's are newer creations, and I would think the axles are smaller/lighter weight.
SO...to be on the safe side, select either a XS650 or 1100 or XJ11 wheel!
T.C.T. C. Gresham
Yes, the XS1100 front wheels are all the same. Now, you may need to swap out the speedo drive from the XJ wheel though.Life is what happens while your planning everything else!
78 XS750Comment
