XJ11 fork seal replacement
  • KA1J
    • 664
    • Groton, CT
    Happy almost spring!
    I'm about to do the front fork oil seal replacement as the left seal has ruptured. I bought a pair of the red seals Chacal sells and am wondering if there is any advice for procedure with the XJ11 I need to be aware of. I looked around for a step by step guide for dummies but didn't strike gold. Any nice pictorial for it you might know of or suggestions to save me confusion or time without cutting quality corners?
    Thanks,
    Gary
    Look here.... http://www.xs11.com/forum/showthread.php?t=37399
    • KA1J
      • 664
      • Groton, CT
      WooHoo! Yup, I missed it! Thanks for pointing it out, that's just exactly the info I need. Wish I had one of those junk trees to use in my vise but I'll have to make do without.
      Cheers!
      • Petersg_99
        • Apr 2012
        • 184
        • Phoenix, AZ.
        kind of a stupid question, but how do you know if the fork seals need to be replaced. I can guess oil squirting out of the forks is one indicator, but is there any other symptom of worn out seals?
        Guy
        1980 XS1100G - Frankenstein - resurrected from the impound lot
        1991 Suzuki GS500E (not running yet)
        2003 Burgman AN400 - Blue Belle
        2005 Burgman AN400 - Silver Belle
