wind problem
  • eddielo
    • Mar 2013
    • 35
    • San Jose, CA
    wind problem
    Hi everyone. Just came on board. Hope to lurk for a while to learn as much as I can about this sweet bike. But I do have one question. I did a search first, as is customary, but I could not find anything related to my question.
    The first day I took my Eleven out I went on the freeway. I was doing about 60 to 65 with a slight southerly wind. I was driving EB. I noticed the bike was suddenly becoming hard to steer. I had to decrease speed a little but didn't seem to make a difference. The bike was just being blown all over the place. I had to hold on really tight.
    Is this common when one encounters wind? I know it's not a very heavy bike but I found it odd that the wind was giving me such a hard time. I also drive a BMW LT. At 850lbs, wind doesn't seem to effect it too much.
    Thanks all, hope to learn a lot here.
    Eddie
    2006 Yamaha Morphous "The Space Ship"
    2004 Honda Aero VT750 "Black Beauty"
    2003 Yamaha VStar 650 Classic "primero"
    2000 BMW K1200LT Like new as of 5/10/16
    1999 BMW K1200LT "The Silver Bullet"
    1996 Kawasaki KZ1000P "the 5-0"
    1989 BMW K100RS "White Ghost"
    1986 Honda Goldwing Espencade 1200 (work in progress)
    1982 Honda Goldwing Interstate 1100 (same)
    1980 Yamaha XS1100 fast
    1979 Yamaha XS1100 just as fast
    +6 CTs
    • 8794
    Lot of things can contribute, poor condition tires, sticky steering head bearings, weak springs, low fork oil, worn wheel bearings, etc. Sure the wind might blow you around a bit if everything is working ok, but problems like this can make it seem even worse.
    07 Triumph Tiger 1050
      • 7941
      A luggage rack with a load on it will mess you up too!
        I would agree with these guys, its most likely something mechanical, not the wind.
        • jayel
          • Apr 2012
          • 152
          • Birmingham, Iowa
          do you have a windshield or fairing on the bike? what is your tire air pressures?
          where are we going, and why are we in this hand basket?
          Iowa the Beautiful Land 1980 XS1100SG
            • 7941
            I have a barn door windshield on mine and the wind doesn't bother it.
            • jayel
              • Apr 2012
              • 152
              • Birmingham, Iowa
              if he just put one on and/or if it's set up wrong it could effect his perceived handling, but more likely tires, air pressures, loose swing arm or fork bearing issues, just trying to cover all the bases
                • 7941
                Right, you are. I think anything that unloads the front tire might cause an issue, no?
                • TomB
                  • 967
                  • Cumbria, UK
                  Wind problem
                  Me too, the wife plays hell
                  Tom
                    • 5062
                    My bets are on the steering head bearing. Maybe old hard grease in there.
                      Hey Skids,
                      That was my thoughts also. What I like is that this guy is the first one to say our bike is LIGHTWEIGHT...but compared to his 850 lb BMW, it IS!
                      I've experienced side/cross winds, remember some fond 40mph ones coming off of Lake Ontario at 9pm at ~40 degree temps during my ride up to XS East 2002....caused me to ride at a ~60 degree left lean angle, but was otherwise able to maintain a straight line of direction.
                      Eddie, support the front wheel off the ground with a jack under the front frame/engine and on the centerstand, and then move the handlebars left and right and see/feel if it feels notchy and such. If it's not glass smooth, or does not fall to either side with just a slight nudge, then the steering head bearings are gummed up. You may NOT need to replace the actual bearings, but just disassemble, clean and regrease....just inspect the races for notches while it's apart. Welcome to the madness, and YES these are SWEET bikes!
                      • eddielo
                        • Mar 2013
                        • 35
                        • San Jose, CA
                        Hey Skids,
                        Thanks TC, great replies. I'll start checking 'em out.
                        +6 CTs
