Removing cable from clutch end??
  • Courtney
    • 542
    • Nanaimo BC Canada
    Ok, popped sidecover loose, it's sitting on the engine still. I went to remove the sidecover end of the cable, but there's no slot to slide the cable end out of it's bracket???? How the heck are we replacing a clutch cable, or does it come with a whole new bracket and pivot pin etc etc? I've looked at it 3 different ways and it looks like I either remove the pivot pin or unscrew the center adjust and nut right off and remove the lever too???
    Bone stock 1980 Special except for the exhaust and crashbars. Oh yeah, and the scabbard for the Winchester Defender.
    Look closely, and you'll see a little 'tab' that needs to be bent out of the way. Try not to break it off, so be gentle....
    • Courtney
      • 542
      • Nanaimo BC Canada
      Oh for cryin' out loud, I've NEVER seen that kind of setup in a million years on bikes! Thanks Steve! I'm used to the slot you pull the cable end down and through.
      • clcorbin
        • Jan 2010
        • 495
        • Albuquerque, NM
        And you will never ever be able to say that again!!!
        -- Clint
        • Courtney
          • 542
          • Nanaimo BC Canada
          isn't that the truth!
          BTW, my wife and I will be cruising through Albuquerque this May or June for a little return trip down Route 66. Awesome part of the world. I'd live in New Mexico anytime!
            Courtney, If you come all the way out to Can'taffordya, look up Special Ed and I. We can help with a GREAT day ride, and it would be good to meet up, as I hope to be in your area mid September. We are on the Monterey Bay, and know most of the good roads in this area. Check with 3phase for the LA/Southern Cal side of things, as that is his stomping ground.
              Oh for cryin' out loud, I've NEVER seen that kind of setup in a million years on bikes! - - -
              Hi Courtney,
              it's another one of Yamaha's brilliant ideas. The XS650 clutch cable retainer works the same way.
              The little tab will snap off the second time it gets straightened and re-bent.
              But not to worry, the cable will work without the little tab.
              Just keep an eye on it as you hook up the lever end.
              Once the cable is in at both ends it can't fall out.
              • Courtney
                • 542
                • Nanaimo BC Canada
                Yeah that sounds about right Fred. I can see that some creative safety wire or a zip tie will be getting used in the future if it does break off. Stupid idea.
