what can i do to desqueek the brakes. I have new pads. i cleaned the orfice holes in both masters, the owner before me let the front brakes lockup a few times i suspect. the brakes work fine but they squeek. thanks in advance brian
squeaky brakes (help)
chamfer the edges if the pads at about 54 degrees (just need to do leading edge but if you do both edges you can't mix them up). Also "anti-squeel" (available at auto parts stores) compound on the back of the pads helps too. Make sure the metal anti-rattle shims are in place.Pat Kelly
<p-lkelly@sbcglobal.net>
1978 XS1100E (The Force)
1980 XS1100LG (The Dark Side)
1999 Suburban (The Ship)
1994 Dodge Spirit (Son #1)
1968 F100 (Valentine)
