what can i do to desqueek the brakes. I have new pads. i cleaned the orfice holes in both masters, the owner before me let the front brakes lockup a few times i suspect. the brakes work fine but they squeek. thanks in advance brian
squeaky brakes (help)
Tags: None
chamfer the edges if the pads at about 54 degrees (just need to do leading edge but if you do both edges you can't mix them up). Also "anti-squeel" (available at auto parts stores) compound on the back of the pads helps too. Make sure the metal anti-rattle shims are in place.Pat Kelly
<p-lkelly@sbcglobal.net>
1978 XS1100E (The Force)
1980 XS1100LG (The Dark Side)
1999 Suburban (The Ship)
1994 Dodge Spirit (Son #1)
1968 F100 (Valentine)
"No one is totally useless. They can always be used as a bad example" -
