Hi TC,
FWIW, 27mm is the same size as 1-1/16" so the wrench from the inch set will work perfectly.
There are several "near misses" (11mm/7/16" 14mm/9/16" 16mm/5/8" etc.) where the mfrs wrench tolerances let you get away with inch/mm wrench swaps but 27mm/1-1/16" is the only one that's perfect.
OK. within 0.0005".
OK. within 0.0005".
Hey could you give me the measurements of your ammo cans so I could have an idea of what this may look like. Just wondering if you are using the same ones. Also, did you use the XS bag mounts or did you make your own. Just trying to find out about where they are going to sit on the bike. Thanks.
