That's not a XS (or even XJ) M/C; that's off a newer bike, so the PO has swapped parts on you. Probably your cheapest solution would be to get a XJ clutch perch which does have an 'angled' mirror mount and will match up with the existing lever/clutch cable. Not guaranteeing the angle will match exactly, but should be closer.
The other choice is to go back to a XS M/C, but they're getting hard to find.
